Adobe Workstation Help
Post Date: 2011-08-19
Miraj View Drop Down
  Quote Miraj Quote  Post ReplyReply bullet Topic: Adobe Workstation Help
    Posted: 19 Aug 2011 at 5:29pm
Less than $3000 would be perfect, but no more than $4000
Last for a very long time (4 years, atleast), remain chilled and as silent as possible. Handle multiple monitors well and Adobe Softwares, especially Photoshop, Illustrator, After Effects, and InDesign.
Web/Graphic design, and sometimes video editing. I won't be doing much 3D rendering, if anything I might use C4D occasionally for text in motion graphics.
I bought a XM15 Level 4 notebook a few months ago from here, and I love it. I am heading to college very soon, and I am thinking about using the notebook for only college purposes or whenever I need to travel. I need this desktop to last, incase I wear my notebook out from commuting. I will also be doing all my web/graphic design work on the workstation rather than on the laptop. I multitask a lot and always have too many apps and tabs open on my taskbar and browser. This workstation should be able to handle this, and last me through college.
Saved Ticket #: 588080
Chassis Model: Digital Storm PROTUS
Processor: Intel Core i7 950 3.06GHz (Quad Core)
Motherboard: EVGA X58 SLI 3 Edition (USB 3.0 & SATA 6Gb/s) (Model: 131-GT-E767)
Hard Drive Set 1: Operating System: 1x (40GB Solid State (By: Intel) (Model: X-25V Edition) (Extreme Performance) <b></b>
Hard Drive Set 2: Multimedia\Data: 1x (1.5TB Hitachi Deskstar (7200 RPM) (64MB Cache) (Model: 7K3000)
Internet Access: Wireless PCI 802.11n Up to 300Mbps (Supports 802.11n/g/b) (Model: 3FMPCIMWN-R) <b></b>
Video Card: NVIDIA PNY Quadro 4000 2GB (Outputs: DVI, DisplayPort) <b></b>
Boost Video Card: Option Not Available
Boost Memory: Option Not Available
Warranty: 4 Year Platinum Care Extended Parts & Labor Warranty (Highly Recommended)
I customized the low-end protus. I have been told to have Xeon Processors, Quadro 4000 or 5000 GFX card, and SSD boot drive for optimize for adobe software. I don't know if I will be needing all this, I am not really an expert. I'd like to keep the price as low as possible. Thanks for the help, :D
Edited by Miraj - 19 Aug 2011 at 5:30pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 19 Aug 2011 at 5:47pm
That config is the old platform, the new platform will give you better performance, you should wait for the highend platform that will be out in oct/nov, that has the 6 core cpu that is what you need/want for your work.
your ssd is the old gen also, you need more IMHO.
  Quote Miraj Quote  Post ReplyReply bullet Posted: 19 Aug 2011 at 5:51pm
OCT/NOV? How about specs from Black Ops?
https://www.imagenskins.com - Social Blog
https://www.enfusedesigns.com- Web Studio
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 19 Aug 2011 at 6:17pm
right now the 2600K is king and the new 6 core cpu coming out in oct/nov will be the new king.
check out this thread
  Quote Miraj Quote  Post ReplyReply bullet Posted: 19 Aug 2011 at 6:22pm
Alright thanks for your help. Guess I'll get iPhone5 and my dream machine at the same time.
Edited by Miraj - 19 Aug 2011 at 6:23pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Aug 2011 at 4:19pm
My pleasure and good luck
