Advice and opinions
Post Date: 2012-09-15
jljjr27 View Drop Down
  Quote jljjr27 Quote  Post ReplyReply bullet Topic: Advice and opinions
    Posted: 15 Sep 2012 at 3:33pm
Hello everyone,
Looking for some help for my next computer purchase. For some sympathy the following is what I'm currently using:
Dell Dimension 8400 Pentium 4 3.40ghz
GeForce 9500gt
Dell 1704fpt
150gb for storage (huge I know)
So I think it's time for an upgrade lol.
1. Budget: 1,500 max 2,000
2. Expectations: Looking for a computer I can easily upgrade and not have to replace in a year.
3. Usage: I have a World of Warcraft addiction and have to play on the lowest setting and sometimes have to fight with lag in our 25 man raids. Would love to play on highest settings with no problems for once. Usually always on my computer web surfing and will be adding windows office.
I love the Corsair 600t white case, so naturally the ODE V2 seems like a common sense buy. Looking at level 3 and that's where I'm torn with the ODE and the below set up. I have never built a computer but I have watched a ton of videos on the egg and don't think it's too intimidating.
CPU: Intel Core i7-3770K 3.5GHz Quad-Core Processor
CPU Cooler: Corsair H100 92.0 CFM  Liquid CPU Cooler
Motherboard: Asus P8Z77-V PRO ATX  LGA1155 Motherboard
Memory: Corsair XMS3 16GB (2 x 8GB) DDR3-1600 Memory
Storage: Western Digital Caviar Black 1.5TB 3.5" 7200RPM Internal Hard Drive
Storage: Corsair Neutron Series GTX 120GB 2.5" Solid State Disk
Video Card: Asus GeForce GTX 670 2GB Video Card
Case: Corsair 600T White Graphite ATX Mid Tower Case
Power Supply: Corsair Professional Gold 850W 80 PLUS Gold Certified ATX12V / EPS12V Power Supply
Optical Drive: Asus BC-12B1ST/BLK/B/AS Blu-Ray Reader, DVD/CD Writer
Monitor: Asus PA248Q 24.1" Monitor
Operating System: Microsoft Windows 7 Home Premium SP1 (64-bit)
Total: $2162.10
If this violates any forum rules please delete with my apologies just looking for some advice from a company that impresses me with their quality of products. Thank you for any advice and help and sorry for the wall of text.
DomTheBomb View Drop Down
  Quote DomTheBomb Quote  Post ReplyReply bullet Posted: 15 Sep 2012 at 7:59pm
Welcome to the forums!
First off, for your budget the ODE series is definitely the best. You get excellent power for a great price with any of the ODE levels. Whichever one fits your budget best would be the one I would recommend. The level 3 seems to be perfect, and is built with really good components that will max out many games.
Second off, you're right, building a computer is pretty easy and you could probably make a computer with the same specs for cheaper. However, there are a few main reasons I would suggest buying from Digital Storm:
-The warranty: Digital Storm has a standard 3 year warranty on their computers. It is a lot simpler to have one warranty as opposed to one for each individual piece of hardware. The customer service is also incredible.
-They build it: Not only does it save you time, but DS only builds high quality computers. There aren't going to be wires all over the place, and they will send you a computer that works. A single mistake building a computer can make the whole project cost a lot more, so buying from DS gets rid of that risk. They also overclock it for you and make sure it's stable so you don't have to worry about that.
So if you think that the little amount extra you end up paying is worth the warranty, time saved, quality, and stability guaranteed is worth it, I would recommend Digital Storm.
Also, if you look up individual prices of components, it comes out to be pretty close to the price of the ODE.
DS x17, 1 Year 5 Months
i7 3720QM (2.6GHz/3.6GHz)
16GB 1600MHz DDR3
Nvidia GTX 680M 4GB
240GB Intel 520 SSD
Windows 8.1 Pro
marccody View Drop Down
  Quote marccody Quote  Post ReplyReply bullet Posted: 15 Sep 2012 at 9:21pm
As the person above me said welcome :)
anyhow. For what you need the any ode will easily run WoW on max settings on any raid. IMO a ode level 1 will suit you rather well unless you want to sli your graphics card later on but you can always do a custom build :)
In terms of building it yourself. Yes it will always be cheaper. So it is up to you. I added up the cost of a ode level 1 and compared it to buying and building it myself (was a month ago). It game out to about 1300-1350 to build it myself. So in other words I was paying 150 to 200 bucks for them to build it for me, test it out, overclock it to stability, and get a 4 year warranty. Also I know that if I have ANY problems I can come on the forums or call them at any time for help. So its up to you.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 16 Sep 2012 at 6:20am
Yep, what DomTheBomb and marccody said.  Big%20Smile
You can save about 10% or so doing it yourself, and I have done it, but it's nice to know if something goes belly-up I can call DS, with US support,  and get the problem identified and the part in the mail the next day.
Parts you buy will have their own warranty but one stop fixing is nice.
ODE's are best bang for the buck.   You could go to a custom config if something about the ODE doesn't hit you but it would be a bit more.
Here's a custom config just to play with and see.
Config # 729215     Cost $ 1945
Chassis Model: Special Deal Hot Seller - Corsair Carbide 500R (White Finish)
Processor: Intel Core i5 3570K 3.40 GHz (Unlocked CPU) (Quad Core) (Requires Z77 Motherboard)
Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: Corsair) (Model: Force GT Series CSSD-F120GBGT-BK) (SATA 6Gbps)
Optical Drive 1: ASUS Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Model: BC-12B1ST)
Video Card: 1x NVIDIA GeForce GTX 670 2GB (Includes PhysX)
Just for different I put in the white 500R case, but that's changeable.  I think DS will use the 600T White if asked for in a custom build.   You said you like white, and it is nice, but if you want the best then check out the HafX under Dreadnought.  Either of these cases get the job done, however.
The 3570k chip is less than the 3770k but all gaming needs.
The Sabertooth mobo has a 5 year warranty as opposed to most with 3 year warranty and it can sli, 2x video card, unlike the ODE 3's mobo.
The Noctua D14 air coler is huge compared to the Vortex 240mm but it leaves very little to go wrong and works great.  the Vortex also works very good and does have a good track record.
The gtx 670 is less than the ODE 3's 680 but it is very close in gaming performance, in most cases only a few fps difference.
Just something else to check out.  The ODE is tough to beat for your budget.
Good Luck. Big%20Smile
Dang Oops  I forgot the free t-shirt.
Edited by bprat22 - 16 Sep 2012 at 6:25am
  Quote marccody Quote  Post ReplyReply bullet Posted: 16 Sep 2012 at 10:42am
If you do a custom build I highly recommend at gtx 670 or 660ti. Those two are the best bang for your buck currently.
Proud owner of Ode level 1
Gtx 670 2gb
i5 3570 @ 4.2
  Quote jljjr27 Quote  Post ReplyReply bullet Posted: 23 Oct 2012 at 3:59pm
Hi all,
Thank you for the responses. Can you guys review this build also, i don't mind spending the extra money for the i7. Quick question about the added lighting, can I turn it on and off or is it always on. Thank again
Ticket # 740901
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 23 Oct 2012 at 4:06pm
That build looks real nice.
There is a switch on the back i/o panel to turn internal lights off/ on.
  Quote jljjr27 Quote  Post ReplyReply bullet Posted: 23 Oct 2012 at 9:27pm
Thank you! Ordered, now for the agonizing wait!!
  Quote FrankW Quote  Post ReplyReply bullet Posted: 24 Oct 2012 at 9:27am
Hi jljjr27,
I am late to the party but please consider this. For $300 dollars more you can get the ODE-4. This will give you the white case, SLI 670s 2Gb, 16Gb of memory and a Blue Ray player DVD burner. Everything else the same as your build.
I know you have just places your order and you can still make this change if you have the bucks. Just a thought.
  Quote jljjr27 Quote  Post ReplyReply bullet Posted: 24 Oct 2012 at 4:40pm
Thanks for the advice Frank. I need to upgrade my monitor and it will be about the same $300. This set up should last me and I can add another card when the need arises.
  Quote jljjr27 Quote  Post ReplyReply bullet Posted: 25 Oct 2012 at 2:53pm
Now that I'm waiting, any advice on a decent monitor. Thanks!!
  Quote Asangard Quote  Post ReplyReply bullet Posted: 25 Oct 2012 at 8:39pm
Hi jljr27,
The Dell Ultrasharps are really good monitors.  I lot of folks here use the U2312HM.  Here is a side by side comparison between the U2312HM and the U2412M at Newegg.
