Advice/Feedback on Devil's Canyon build.
Post Date: 2014-06-07
ohlmsjm View Drop Down
  Quote ohlmsjm Quote  Post ReplyReply bullet Topic: Advice/Feedback on Devil's Canyon build.
    Posted: 07 Jun 2014 at 7:48pm
$6500
Smoothest gaming experience on highest/ultra settings. Run dual monitors at 1920x1080 but don't plan to span games across both. I expect the system to last a good 6 years. OS will be loaded on the 256SSD, the other 512GB SSD will be all games/steam.
70% gaming (mmo, fps, moba, rpg, [Steam games as well]), 20% surfing/streaming, 10% photoshop/illustrator work.
Fiancee and I have several cats. Office is on a second floor so it gets warm in the summertime. Based on those, we want a system that's quiet, emits little heat, and tries to stave off the feline fur fiasco!
Saved Ticket #: 989669
First time going through Digital Storm and definitely wanted to bounce this system off of others before pulling the trigger. Ideally, I really wanted the full on copper pipe custom cooling system and supplemental controls but felt it was pushing the build budget just beyond what I wanted to spend. I'm also not aware of how much maintenance would be involved with a custom cooling setup as I've never had one.
I would love to hear some feedback on the build, maybe criticize choices, etc. Thanks and definitely looking forward to the responses.
BUILD DETAILS
Chassis
Chassis Model: Black OPS Aventum II
Exterior Finish: Onyx Black Matte Finish with Red Stand
Core Components
Processor: Intel Core i7 4790K 4.0 GHz (Codename Devils Canyon) (Unlocked CPU) (Quad Core) (ETA 6/25/14)
Motherboard: ASUS MAXIMUS VII HERO (Intel Z97 Chipset) (The Ultimate Power Platform)
System Memory: 16GB DDR3 1866MHz Corsair Vengeance Pro (High-Performance)
Power Supply: 1200W Corsair AX1200i (Digitally Controlled Power)
Storage / Connectivity
Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 8x / CD-Writer 8x) (Slim Slot Loading Edition)
Storage Set 1: 1x SSD (256GB Samsung 840 PRO)
Storage Set 2: 1x SSD (512GB Samsung 840 PRO)
Graphics / Multimedia
Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 780 Ti 3GB (Includes PhysX)
Digital Storm Engineering
Extreme Cooling: H20: Stage 2: Corsair H110 280mm Radiator Liquid CPU Cooler (Extreme-Performance Edition)
Chassis Fans: Upgrade All Fans to Corsair Airflow Performance Edition (Up to 6 Fans)
Noise Reduction: Noise Suppression Package Stage 2 (Optimized Airflow & Fan Speeds with Noise Dampening Material)
Digital Storm TwisterBoost Technology
Boost Processor: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires High-End Motherboard Selection)
Software
Windows OS: Microsoft Windows 8.1 Professional (64-Bit Edition)
Accessories / Goodies
Customer Care
Warranty: Life-time Expert Care with 6 Year Limited Warranty (6 Year Labor & 4 Year Part Replacement)
Edited by ohlmsjm - 07 Jun 2014 at 9:55pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 08 Jun 2014 at 1:49pm
Hi ohlmsjm.... You put together a real nice rig.   My only suggestion would be to consider a single gtx 780ti for your 1920x1080 single gaming monitor.   The second card will, for the most part, just sit there with nothing to do.   As gaming gets more demanding a new generation card in a year or two will keep you on top.   6 years is pushing it with no video card upgrade.
The HydroLux custom water requires little maintenance. Mainly topping off the reservoir as needed and maybe a system flush every couple of year.   Pretty simple. Swapping parts during an upgrade or a defective part does get more complicated, however.      The H110 you selected is maintenance free and will cool the cpu just fine.   Depends on the budget.
For dust, cat hair, etc, the best defense is keeping the rig a foot or two off the floor where the dust and fur like to swirl around.
If by chance you do drop to a single card, you can also drop the psu to an 850watt.   The single card also means less heat output into the room.   Stage 1 overclock will give you close performance to stage 2 and also generate less heat.
Hope this helps and good luck. The Aventum is a nice setup.
Edited by bprat22 - 08 Jun 2014 at 2:18pm
Nav View Drop Down
  Quote Nav Quote  Post ReplyReply bullet Posted: 08 Jun 2014 at 2:29pm
bprat22 pretty much nailed it all on the head.
There have been some issues in the past regarding the H110 not working with the Aventum II due to the tubing not being long enough. I would recommend switching to either the Noctua cooler or going with a custom loop.
Edited by Nav - 08 Jun 2014 at 2:29pm
  Quote ohlmsjm Quote  Post ReplyReply bullet Posted: 08 Jun 2014 at 2:46pm
Thank you so much for the feedback thus far. Taking into account your recommendations this is what I've assembled:
Saved Ticket#: 990053
Chassis Model: Special Deal Hot Seller - Black OPS Aventum II
Trim Accents: - Not Available
Power Supply: 850W Corsair RM850 (Optimized for Silence)
Graphics Card(s): 1x NVIDIA GeForce GTX 780 Ti 3GB (Includes PhysX)
Extreme Cooling: H20: HydroLux Copper: Digital Storm Copper Pipe Custom Cooling System (Video Cards + CPU + Chipset)
Airflow Control: - No Thanks
Portable Gaming: - No Thanks
Nav View Drop Down
  Quote Nav Quote  Post ReplyReply bullet Posted: 08 Jun 2014 at 2:48pm
Looks like an overall solid build. Regarding dropping to a stage 1 OC, considering you have gone with a custom loop heat won't be an issue and the Devil's Canyon chip can definitely hit 4.5-4.8.
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 08 Jun 2014 at 2:49pm
The Noctua can fit in the Aventum 2???
Nav View Drop Down
  Quote Nav Quote  Post ReplyReply bullet Posted: 08 Jun 2014 at 2:55pm
There isn't a reason it shouldn't unless i'm forgetting something.
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 08 Jun 2014 at 3:09pm
Maybe i should buy an aventum 2 with the noctua cooler....lol
Nav View Drop Down
  Quote Nav Quote  Post ReplyReply bullet Posted: 08 Jun 2014 at 3:18pm
Well you pretty much lose the purpose (exhaust chamber) but you do get one bad-ass looking case
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 08 Jun 2014 at 3:40pm
For some reason, as much as I like Noctua, it just doesn't seem to be an Aventum thing.
The latest build looks great.
