Advice for a GTX 480 centered build
Post Date: 2011-03-19
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Topic: Advice for a GTX 480 centered build
    Posted: 19 Mar 2011 at 10:16pm
Long story short, my robotics team happened to win a GTX 480 over the weekend...which is freakin awesome btw...but now that we have a killer graphics card to do some rendering on we're going to instead just build a new computer system centered around it in order to use it since the HP mini-towers at the school obviously won't work too nice with it. We can't sell the card for an equivalently powered and cooler running 570, unfortunately, so we definitely have to use the 480. Therefore....I'm looking right now for the cheapest possible configuration that'll work with the 480 without bottlenecks, can I get any suggestions?
Oh, and how do you think a Silverstone RV01 would work with it...I was planning to swap over to the RV03 sometime soon when it releases, and could put my RV01 to good use i guess.
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
maxyme View Drop Down
  Quote maxyme Quote  Post ReplyReply bullet Posted: 19 Mar 2011 at 10:25pm
your school has better computers than mine. we have at the best core duos and worst pentium 1s i think. some computers don't have enough ram to run office 2010.
go with the i5 old 8xx socket i think 6gb ram and 750w psu
edit: if you are going to be doing rendering on it consider the i7 8xx socket its not much more expensive and the extra threads will help with rendering since its cpu and gpu heavy.
Edited by maxyme - 19 Mar 2011 at 10:30pm
Steam:pcmaster160
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 19 Mar 2011 at 10:56pm
No SB? I was thinking of overclocking one of those, heh, btw for anyone that's overclocked a SB processor how easy is it? The people at my school (taking a course called A+ Comp. Maintenance) are extremely skeptical against overclocking but hey, if it isn't that risky i might convince them to let me at it heh.
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote RiceEatin2000GT Quote  Post ReplyReply bullet Posted: 19 Mar 2011 at 11:00pm
dont trust kids in a high school grade level computer class(think its high school?)
  Quote maxyme Quote  Post ReplyReply bullet Posted: 19 Mar 2011 at 11:08pm
hey i'm in high school! lol
as far as i know there isn't much risk just slowly bump up the vcore and the multiplier. i didn't choose sb because you can get great deals on the old socket. But thats just to get a pretty good deal.
Steam:pcmaster160
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Mar 2011 at 12:11am
As you know I got 4 x 480 and under load with the LC they are warm, so either get lc on it or get a case like haf x with lot of air flow.
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 20 Mar 2011 at 1:15am
LC on just one?
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Mar 2011 at 2:24am
if you plan on oc and having it under load for long period of time, yes, LC just one, these guys are running warm, I got a triple 140mm rad with 6 push/pull and my load temps are anywhere from 50c to 70c depending on room temp.
as you can see load temps here are low, cpu and gpu are under full stress 99% +, they have been so for days now, which is the norm:
Edited by DST4ME - 20 Mar 2011 at 2:31am
Treelox View Drop Down
  Quote Treelox Quote  Post ReplyReply bullet Posted: 20 Mar 2011 at 4:56am
So DST you just use your PC as a space heater during the winter, right?
:P
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Mar 2011 at 5:40am
lol if you put it close to the window, it will stop the cold air from coming in , seriously tho, it does heat up the room about 10f.
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 20 Mar 2011 at 2:30pm
Ah, no, i just meant a CPU overclock hehe. Don't see much of a need to overclock the GPU.
Any ideas on parts for the lowest costing, least bottlenecking system for it though? Case could be a RV01, and GPU again is of course mandated to be a GTX 480.
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
Dragoonseal View Drop Down
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 21 Mar 2011 at 12:03pm
When I had just one 480 in Lilim it would max out at 79°C at 79% fan speed. Having two in SLI they only max out at about 86°C at 86% fan speed and 81°C at 81% fan speed. You don't have to worry about LCing.
(Using this MSI Afterburner fan profile:)
Lilim
Intel Core i7 920 @4.2GHz
coolmasta View Drop Down
  Quote coolmasta Quote  Post ReplyReply bullet Posted: 21 Mar 2011 at 1:28pm
Sandy bridge K series is very easy to OC btw.
I7 2600k @ 4.5 Ghz, Noctua D14
8 Gigs Corsair 1600
HAF 922
Evga Gtx 580
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 22 Mar 2011 at 3:12am
What is your room temp dragoon?
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 22 Mar 2011 at 3:48pm
Usually 70-72°F.
Lilim
This page was generated in 5.957031E-02 seconds.
