Advice for Lumos Build
Post Date: 2020-06-10
007jrod View Drop Down
  Quote 007jrod Quote  Post ReplyReply bullet Topic: Advice for Lumos Build
    Posted: 10 Jun 2020 at 8:35am
Hi everyone, pretty new to this so bare with me please! I've been looking at gaming PC's for a while now, and finally settled with Digital Storm and so far seems like I made a good choice.
I (stupidly) couldn't contain my excitement and put together a build and purchased it before checking with the pros (you all)... So hoping someone can take a quick look at my build and let me know if there's anything that doesn't make sense or that I should reach out and change ASAP (if they let me). Main purpose will be for games like the Witcher, COD, maybe WOW, etc.
I just received an email yesterday starting Stage 1.
From what I (think) have learned, I think my Graphics card might not be up to par with everything else I chose, but hoping someone can let me know if I made good choices or if I should try to change something around!
P.S. My budget was around $2200, and ended up about $2550 out the door... so oops..
Processor: AMD Ryzen 7 3700X (8-Core) 4.4 GHz Turbo
Motherboard: ASUS PRIME X570-P (AMD X570 Chipset) (Up to 2x PCI-E Devices) (No SLI Support)
System Memory: 16GB DDR4 3000MHz Corsair Vengeance RGB Pro (RGB Light Bar)
Power Supply: 600W Digital Storm Performance Series (Supports up to an NVIDIA RTX 2070 GPU)
Optical Drive: - No Thanks
Storage Set 1: 1x SSD M.2 (1TB Samsung 970 EVO PLUS) (NVM Express)
Internet Access: Wireless PCI-E (Supports 802.11ac)
Graphics Card(s): 1x GeForce GTX 1650 4GB
Extreme Cooling: H20: HydroLux LITE: Integrated Cooling System (CPU Only)
HydroLux Fluid Color: Green Flexible Tubing + Clear Fluid (Requires HydroLux Liquid Cooling System)
Cable Management: Exotic Cable Management - Black - (Cable Combs with Custom Color Sleeved Extension Cables)
Airflow Control: - No Thanks
Graphics: Yes, Overclock the video card(s) as much as possible with complete stability
Mouse Pad: - No Thanks
Keyboard: Digital Storm Devastator Bundle (RGB) Keyboard & Mouse
Branded Gear: - No Thanks
Priority Build: - No Thanks, 6 Week Ship Estimate After Order Is Successfully Processed
Muz View Drop Down
  Quote Muz Quote  Post ReplyReply bullet Posted: 10 Jun 2020 at 9:31am
Hello. Great choice. Just let us know what your normal resolution will be to play at ie: 1920x1080, 2560x1440 or 4k and we can help you.
  Quote 007jrod Quote  Post ReplyReply bullet Posted: 10 Jun 2020 at 9:38am
Hi Thanks for the response.
I will probably start with 1920x1080, and then move up to 2560 or 4k by november/december time.
