Advice on a PC for MMOs mostly
Post Date: 2013-02-23
Dark Snail View Drop Down
  Quote Dark Snail Quote  Post ReplyReply bullet Topic: Advice on a PC for MMOs mostly
    Posted: 23 Feb 2013 at 5:59am
Budget: 2600 I need everything (Monitor, Keyboard mouse etc)
Usage: Mostly for MMOs Guild wars 2, The Elder Scrolls Online and PC exclusives like Starcraft, Diablo. I play a lot on my Xbox 360 and If I can get the game for the 360 I will not play in on the PC, so the PC is for MMOs mostly.
Monitor: I like the U2412, I only want a single monitor
ODE: I really like the ODE's but I am not sure which one I should go for. I was thinking a level 3, but do I really need a level 3 for my usage or would a level 1-2 one just do fine for me. I want to play these games on high settings and want them to look as good as possible just like everybody else. I just wondering how much more performance I get with the higher Levels.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 23 Feb 2013 at 8:34am
Hi Dark Snail....  Welcome to the forums.
The ODE lvl 1 is all you need for gaming on a single monitor.   The GTX 670 will play most games on High to Max.  Some MMO's can get demanding when the screen gets heavily populated but unless you go sli, 2x gtx 670 then just some minor tweeks keeps things running smooth.
 The ODE 2 has the better cpu but gaming as of now really doesn't utilize it.
The  ODE 3 has a SSD for quicker loads, a Blu-ray player and the GTX 680.  The Gtx 680 is alot more $$ for only a small increase in performance so the 670 in ODE 1 is best bang for the buck.
If you don't care about Blu-ray on the pc or a SSD then go ODE lvl 1.
Hope this helps and good luck. Big%20Smile
