advice on build
Post Date: 2011-05-10
mackraney23 View Drop Down
  Quote mackraney23 Quote  Post ReplyReply bullet Topic: advice on build
    Posted: 10 May 2011 at 11:57pm
this build hopefully less
heavy gaming at max settings
hey i was just wondering if theres any recommendations yall might have. and to simply look over this build and let me know if theres anything i dont need or need. thanks
Saved Ticket #: [538722]
Specifications:Chassis Model: Special Deal Hot Seller - Black OPS HailStorm Edition
Processor: Intel Core i7 Extreme Edition 990X 3.46GHz (Six-Core) (Extreme Performance)
Motherboard: ASUS Rampage III Extreme (Intel X58 Chipset) (Features USB 3.0 and SATA 6Gb/s)
System Memory: 12GB DDR3 1600MHz Digital Storm Certified (Highly Recommended) (Hand Tested)
Hard Drive Set 1: Operating System: 1x (80GB Solid State (By: Intel) (Model: X25-M MLC Edition) (Extreme Performance)
Video Card: 1x NVIDIA GeForce GTX 590 3GB (PhysX) (EVGA Classified)
Extreme Cooling: H20: Stage 5: Sub-Zero LCS Cooling System: CPU & Chipset
H20 Tube Color:Blue Tubing with High-Performance Fluid (UV Lighting Reactive)
Chassis Airflow: Upgrade Chassis With LED Performance Fans (Blue) (Up to 6 Fans)
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 May 2011 at 1:34am
You got the wrong platform, the 2600K will beat the 990 in games and many thing right now.
Not only would I change the platform but I would change just about everything you picked.
right now for less money I can beat your config if power/performance.
but before I do, I need to know what res you gonna be gaming at?
  Quote mackraney23 Quote  Post ReplyReply bullet Posted: 11 May 2011 at 8:33am
okay thanks for the feedback but i will be gaming at 1920 x 1080 or the best looks good on my Dell UltraSharp U2311H 23 moniter. what do you think?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 May 2011 at 3:37pm
I will start with this air cooled, lets discuss it, and if you like it then I will show you how to make it blue.
But if you want LC then let me know.
Here you go Ticket# 539811 --- $2855 (To see this build click here)
Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: Intel) (Model: 320 Series SSDSA2CW120G3K5)
  Quote mackraney23 Quote  Post ReplyReply bullet Posted: 11 May 2011 at 6:40pm
well i was told lc is better. whats your take on it? if it wont make difference then there no pont in paying for it. every thing else looks good. so the the 2 570's in sli are better then the 590?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 May 2011 at 6:47pm
2 single cards will always have better temps, thus can be oced higher, at 1900 x 1200 you will not notice the difference between sli 570/580 and one 590.
dual cpu card run hotter and endup having more problems most times, just ask my 9800x2 and multiple 295 cards.
LC does have better temps for sure, but if you have no need for it then you don't need LC, most times LC is a luxury and not a necessity, many times its just preference, so let me know if you want to see it in LC, price will go up around $1000 I think.
Edited by DST4ME - 11 May 2011 at 6:49pm
  Quote mackraney23 Quote  Post ReplyReply bullet Posted: 11 May 2011 at 7:42pm
okay well i would like to get lc. so will this config be able to max out most of the upcoming games?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 12 May 2011 at 12:26am
My last config will max out just about almost anything at 1900 x 1200, if you want it LCed then:
Here you go Ticket# 540320 --- $3871 (To see this build click here)
Extreme Cooling: H20: Stage 6: Sub-Zero LCS Dual Loop: CPU & Dual SLI/CrossFire Video Cards
you got the best of the best in there, hailstorm is the case I have, its a great case for LC, and it has lot more stuff, you got sli 570 LCed, cpu oc of 4.5 or higher, intel ssd, uv lighting with uv tubes, you got it all.
Edited by DST4ME - 12 May 2011 at 12:28am
  Quote mackraney23 Quote  Post ReplyReply bullet Posted: 12 May 2011 at 3:57pm
okay man thanks for all the help.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 12 May 2011 at 6:39pm
My pleasure and good luck
