Advice on build
Post Date: 2012-02-21
dropdeadcoheed View Drop Down
  Quote dropdeadcoheed Quote  Post ReplyReply bullet Topic: Advice on build
    Posted: 21 Feb 2012 at 2:19pm
Does this build look good and balanced?
[$1,500]
[a gaming pc to run the best games on ultra or very high (crysis 2, metro 2033, and witcher 2) at 1080p & 60fps without AA (no ubersampling or anything like that)]
[GAMING....and Itunes]
Saved Ticket #: [657905]
[Specifications:
Chassis Model: Special Deal Hot Seller - Cooler Master Storm Enforcer
Processor: Intel Core i5 2500K 3.30GHz (Unlocked CPU for Extreme Overclocking) (Quad Core)
Motherboard: ASUS P8Z68-M PRO (Intel Z68 Chipset) (Features Intel Quick Sync Technology)
Hard Drive Set 1: Operating System: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition) <b></b>
Video Card: 1x ATI Radeon HD 6950 2GB
Recovery Tools: Windows Recovery Toolkit (Bundled with Windows 7 CD)]
Edited by dropdeadcoheed - 21 Feb 2012 at 3:06pm
kane860 View Drop Down
  Quote kane860 Quote  Post ReplyReply bullet Posted: 21 Feb 2012 at 6:36pm
I am not really sure if this system is going to be enough to max out games or run on ultra high/high settings.  I am sure others will chime in and provide some better feedback but your budget is a little on the low side for a full out customized rig that will allow ultra high or high settings ... other members can give more info on this...also,  have you checked out the Ode preconfigured rigs?
Edited by kane860 - 21 Feb 2012 at 6:38pm
System:
HAF X942 / i7 3930k 6-core cpu / ASUS P9x79 Deluxe MOBO
16gb DS ram / Corsair 1050HX PSU / Two - Intel 320 series 120gb SSD's
WD Caviar Black 1TB HDD / GTX570 2.5gb GPU / Noctua D14 Cooler
