advice on comp ($2000 range)
Post Date: 2009-12-05
devnull View Drop Down
  Quote devnull Quote  Post ReplyReply bullet Topic: advice on comp ($2000 range)
    Posted: 05 Dec 2009 at 1:21am
Chassis Model: Special Deal Hot Seller - Cooler Master CM Storm Sniper
Trim Accents: - Not Available
Processor: Intel Core i7 860 2.80GHz (Quad Core)
Motherboard: EVGA P55 SLI (Intel P55 Chipset)
System Memory: 4GB DDR3 1600MHz Digital Storm Certified by mushkin enhanced (Highly Recommended) (Hand Tested)
Hard Drive Set 1: Operating System: 1x (1.5TB Seagate Barracuda (7200 RPM) (32MB Cache) (SATA) (Extreme Speed)
Extreme Cooling: H20: Stage 2: Asetek Liquid CPU Cooler (240mm Radiator) (High-Performance Edition)
Enhancements: - Not Available
Chassis Mods: - Not Available
Boost Memory: - Not Available
Office: - Not Available
Benchmarking: - Not Available
Things I wasn't sure about:
Any reason to have the Extreme Cooling? Any benefit to upgrading the mobo? Overall impressions?
Thanks!!!
  Quote devnull Quote  Post ReplyReply bullet Posted: 05 Dec 2009 at 1:30am
Also, I noticed DS doesn't allow more than 4g, I know for most gaming 4g is fine but I do a lot of vm stuff and I figured 6g-8g would be nice for that. Any way to get that much?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 05 Dec 2009 at 1:17pm
what is your budget? and what resolution will you be gaming at?
  Quote devnull Quote  Post ReplyReply bullet Posted: 06 Dec 2009 at 11:06am
Hey thanks for the reply!
My budget is around $2500 unless I could see something super noticeable for $3000 - and by noticeable I mean stuff for general performance (faster for my photoshop/flex/actionscript/premiere/captivate/3ds max work and not necessarily gaming performance).
The resolution to start with will be on a 19" (1440x900), but I may upgrade that to 22" in the near future. That's what I was thinking of spending the remainder ($500) on.
I've been changing the specs around
http://www.digitalstormonline.com/comploadsaved.asp?id=360971
Extreme Cooling: H20: Stage 2: Asetek Liquid CPU Cooler (120mm Radiator)
Boost OS: - Not Available
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Dec 2009 at 1:38pm
Here you go Ticket# 361380 --- Price: $2139 (To see this build click here) Price after current promotion $2139
Hard Drive Set 1: Operating System: 1x (1TB Seagate/Western Digital (7200 RPM) (32MB Cache) (SATA) (Extreme Speed)
Kyu View Drop Down
  Quote Kyu Quote  Post ReplyReply bullet Posted: 07 Dec 2009 at 3:19pm
the setup DST always offer is good. and looks like he saved ya a bunch of money for your monitor.
try to see if you can go 24" now vs 22"
resolution will be about the same, but 22 just seem so small now a days (to me anyways)
Look for
Max Resolution
ms (2-5ms)
contrast ratio (not dynamic)
misc
Sound/watt per speaker
weight
adjustable height
viewing modes
$236.00 for this is a really good price.
just last year I know 2 people who paid 500 for it @ fry's
with 5850 DST recommended you can just plug in HDMI cable and get audio + video
if you got cable tv, just hook that up too. get to watch tv when not using the pc :)
Edited by Kyu - 07 Dec 2009 at 3:19pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Dec 2009 at 3:26pm
well now indays most 22" come with 1600 x 1200 res while the 24" come in 1900 x 1200.
the config is set for a monitor with res of 1600 x 1200, if his monitor is gonna have higher res, then he needs to change his gpu from 5850 to 5870.
having said all that, if his budget does allow, a 24" (1900 x 1200), with a 5870 would be sweet
I think thats a tn panel, sombody just posted a dell that had 178° viewing angle vertical and horizontal.
Edited by DST4ME - 07 Dec 2009 at 3:28pm
