Advice on GW2 Gaming System
Post Date: 2012-08-24
DBAndrew View Drop Down
  Quote DBAndrew Quote  Post ReplyReply bullet Topic: Advice on GW2 Gaming System
    Posted: 24 Aug 2012 at 12:09pm
~$2800 USD
Medium to Medium-High gaming system. Single Display 27" at 1920x1200. Maintain high FPS and provide a great play experience on high settings in MMO Games.
This system will mostly be used for MMO Gaming. I'm still 50/50 on SandyBridge-E vs. Ivy Bridge. Not sure if the SandyBridge-E is overkill or if the Ivy Bridge will be up for the challenge.
I'm coming from a 2.4Ghz(OC 2.8Ghz) sock 775 Quad Xeon, 8GB DDR2, AMD 6870 1GB. This system is getting crushed by Guild Wars 2 on medium settings in 1920x1200, in the large (50vs50) WvW battles I'm seeing 10-15 fps. Normal questing play 5-10 players around is around 25-30 FPS. Busy public quest events with 20-30 players drops to 15-20 fps.
I want a system that will do ~35+ fps in epic scale (100+vs100+) WvW on high settings. Maybe I could compromise and turn settings to medium when I expect epic scale WvW for 30+ FPS. Then the rest of the time change settings to high.
SSD Storage 120GB min. 240GB would be nice. I've never used more then 200GB on any of my gaming systems. I have external USB 3.0 Storage devices for images, video, etc.
MoBo and PSU with option to SLI 2 cards now or later.
Saved Ticket #: 721572
Chassis Model: Special Deal Hot Seller - Corsair Carbide 500R (Black Finish)
Motherboard: ASUS P9X79 PRO (Intel X79 Chipset) (Features USB 3.0 and SATA 6Gb/s)
Hard Drive Set 1: Operating System: 1x (240GB Solid State (By: Corsair) (Model: Force GT Series CSSD-F240GBGT-BK) (SATA 6Gbps)
Video Card: 1x NVIDIA GeForce GTX 680 2GB (Includes PhysX)
Edited by DBAndrew - 24 Aug 2012 at 12:13pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 24 Aug 2012 at 12:25pm
Hi DBAndrew.    That is a great rig.
As far as the platform, if your only gaming then the Z77 with 3770k cpu is all you need.  The X79 platform is a quad channel memory mobo that is for those into Photoshop, Lightroom, 3D modeling, etc that need the wider ram bandwidth to get the job done alot faster.   Nothing wrong with the X79 for gaming, just isn't used.
You could stick with the X79 mobo and drop the cpu from 6 core 3930k to the 4 core 3830 and save $300.  Again, the 4 core is all gaming will use.
For sli the z77 Deluxe is great.  If you ever wanted to go tri-sli, 3x video cards then the X79's 40 lanes of Pcie would be the way to go.
No HDD for cheaper storage, with SSD saved for OS, games being played, etc.
Everthing else looks great.  Real nice Big%20Smile
Edited by bprat22 - 24 Aug 2012 at 12:26pm
  Quote DBAndrew Quote  Post ReplyReply bullet Posted: 24 Aug 2012 at 1:02pm
bprat22,
Thanks for the advice. That is an interesting option dropping the CPU down to the 3820 (3.6Ghz) to save 300$. That makes me wonder which is faster between the i7 3820(3.6GHz) vs. i7 3770K(3.5GHz). I could then put to a 2nd video card and SLI from the start.
I'm still not sure on the quad core vs the hex core. Guild Wars 2 is really new. ArenaNet has their own engine and from what I can tell it is better threaded and uses my 4 existing cores more evenly then any other game. Most games I play (Blizzard, D3,SC2,WoW) have 1 core at like 80% and the other 3 at 40-50% load. I've talked to some friends on AMD CPUs with 8 cores and they claim GW2 uses all 8 evenly. This is why I'm so conflicted on the Hex Core vs. Quad Core.
While I've been playing in the Beta and stress tests, they keep making changes to the performance of GW2. So it will be interesting to see tonight when the game goes live what the performance is like on CPUs with more then four cores.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 24 Aug 2012 at 1:15pm
I think you'll find the 3820 and 3770 will play games about the same, assuming the same oc'ing.
As far as the number of cores, I don't know the games so can't say but the AMD 8 core Bulldozer, I think it is, was never rated very good for core utilization with the 4 core Intels being rated much better.  I never did alot of looking into it, so other AMD fans might slam me.Big%20Smile
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 24 Aug 2012 at 1:38pm
One more quick thought.....   to save $$$$   consider the gtx670 instead of 680.    Its only a few fps slower and $150 cheaper.    In sli, you're saving some bucks.     But, the 680 is a great card so your call of course.
  Quote DBAndrew Quote  Post ReplyReply bullet Posted: 24 Aug 2012 at 2:27pm
Thanks again. I was just reading reviews on GTX 670 SLI.
http://www.tomshardware.com/reviews/geforce-gtx-670-review,3200-16.html
The two GTX 670's in SLI are in my budget reach after changing the CPU to the i7 3820. After reading these reviews, they claim 1920x1200 is easy for a single 670. But then again I don't think they are testing in the same scenario I'm expecting (50vs50 and 100vs100 players). So as much as I would like to SLI, I'm still leaning towards a single GTX 680 for now. Then if I see it getting worked past 80%+ load or so and I'm having FPS issues then I'll add a 2nd one.
Grimme View Drop Down
  Quote Grimme Quote  Post ReplyReply bullet Posted: 24 Aug 2012 at 2:40pm
Hey I just purchased a system a couple weeks ago for the same reason. I got a 3770k and a Nvidia 670 Ftw card, and it plays Gw2 flawlessly. Everything is nice and smooth. The SSD I got also helps immensely with loading times. So if you want to run maxed out a 3770k does exceptionally well, especially considering it will be overclocked to 4.5. For reference I normally play with adaptive vsync on so just 60 fps, out of curiosity I turned it off and was running at 120+fps. So whatever you decide to go with will eat the game up I'd imagine. If you have the money I'd go with SLI, but it would probably be overkill. You can get a single 670 overclock edition and be on par with a single stock 680 and it will save you a bit of cash.
This is the thread where they helped me figure out what I needed in my build. If you were curious about what parts I got.
http://www.digitalstormonline.com/forums/forum_posts.asp?TID=18590
Edit:Gw2 head start is just hours away!
Edited by Grimme - 24 Aug 2012 at 2:45pm
  Quote DBAndrew Quote  Post ReplyReply bullet Posted: 24 Aug 2012 at 2:54pm
Thanks for the advice Grimme.
Did you happen to do any WvW where you are taking or defending a castle with more then 50+ or 100+ players around? If so what was your system like in this scenario? Also what is your resolution and screen size if you don't mind?
  Quote Grimme Quote  Post ReplyReply bullet Posted: 24 Aug 2012 at 3:17pm
I run at 1680x1050. I didn't have any problems with WWW in the last stress test. Unless you count that bug that would warp you all over the map when you used a leap abilityBig%20Smile. Everything ran very smoothly, but you will get some fps dip no matter what kind of computer you have just because the game has to draw 100 people at once. Now once you get into a area and see everything around you it runs super smooth. That initial dip when you first hit a area or a ball of people, after that its smooth as hell. Best example I can thing of is when you first load into a zone and you do a jump with a 360 spin. The fps dips the first time then after that no matter what you do it stays solid.
Just to be clear that dip is literally just going from 60fps with vsync on to 35-45 for a couple seconds and then back up to 60.
Edit: Screen is 22inch @ 1680x1050
Also My processor didn't get over 62 Celsius and my video card only hit 74.
Edited by Grimme - 24 Aug 2012 at 3:21pm
marccody View Drop Down
  Quote marccody Quote  Post ReplyReply bullet Posted: 24 Aug 2012 at 7:19pm
HIgh DBAndrew
I recently just played in the GW2 stress test (yesterday) in WWW with a ode level 1 (i5 3570 overclocked to 4.2, single gtx 670). The game ran at maximum settings and stayed at above 60 frames except for when there were lots of players on the field (30+ dropped to 40 frames, 50 more dropped to around 37. it averaged around 27 for when there was 100+ people on the field). However, I was told before the game that I needed to update my drivers because my current driver has known issues so I might actually get even better frame rates.
Hope that helps :). O and my resolution was 1080P. The only thing I didnt have on ultra was the shadows (medium) and the sampling was at native (not the super sampling). During pve with even the shadows maxed I experenced 70+ framerates up to around 110.
Edited by marccody - 24 Aug 2012 at 7:33pm
  Quote marccody Quote  Post ReplyReply bullet Posted: 24 Aug 2012 at 7:28pm
Also I believe your CPU is overkill for GW2. Its also overkill for gaming in general unless you want to max Rome total war 2 next year.
From what Ive found the gtx 680 is great but the gtx 670 almost matches it and yet is much cheaper.
Heres the framerates for GW2 for each graphic card from Arena Net themselves https://www.guildwars2.com/en/news/bill-freist-talks-optimization-and-performance/
As you can see the Gtx 670 almost matches the 680. Heres more games to compare.
http://www.tomshardware.com/reviews/geforce-gtx-670-review,3200-15.html
Another thing you might of noticed is that AMD cards seem to be slightly better for GW2 (tho I dont know if I would trust those numbers). So if your going to play mostly Gw2 you could go with a AMD card. However, in most other games the Gtx 670 and 680 will outperform the equivalent AMD cards.
  Quote DBAndrew Quote  Post ReplyReply bullet Posted: 24 Aug 2012 at 7:47pm
Thanks for the advice marccody,
The info you provided is exactly what I've been looking for. I would still rather be a little on the overkill side and happy with my system then frame lagging and hating it. I have a 2500 to 2800 budget for the tower. Anything I don't spend here I'll put towards my display and peripherals.
I am considering an ODEv2 Level4. It appears to be the best bang for the buck on an SLI setup. I'm going to see how my friends systems do this weekend during early launch and then I'll buy next week before the end of the month.
Thanks again for the info man. :)
  Quote marccody Quote  Post ReplyReply bullet Posted: 24 Aug 2012 at 7:56pm
As long as it optimizes the sli you cant go wrong with the ode level 4 :). However if you have that much to spend you could go gtx 690 for a single card but im sure that would be overkill. I imagine the frames for GW2 will drop for anyone with a giant army. Some will maintain better than others tho. Ive read online somewhere that a person with a gtx 690 had 60 plus framerates even with huge numbers of players on the field. No idea if he is telling the truth tho.
PS playing guild wars 2 tonight :) another hour hopefully!
Edited by marccody - 24 Aug 2012 at 8:05pm
  Quote DBAndrew Quote  Post ReplyReply bullet Posted: 24 Aug 2012 at 8:36pm
From what I've seen reading several major hardware review sites on SLI with the SLI670 vs SLI680 and the 690. They are all really close to the same up to 1920x1200. I have no plans to play on a display higher then 1920x1200. The SLI680 and 690 don't pull away from the SLI670 until you get into the crazy multi display and/or 2560x1600 and higher resolutions and even then the 670s hang close behind.
  Quote marccody Quote  Post ReplyReply bullet Posted: 24 Aug 2012 at 8:40pm
agreed. And on this site dual sli 670s are much cheaper (if you were to build yourself 690 would be closer). And now that I think about it the gtx 690 is better for higher resolutions so I would def go for the ode level 4. My ode has been great so far. Looks great too :). Case is huuuuugeee so make sure you have room!
  Quote DBAndrew Quote  Post ReplyReply bullet Posted: 28 Aug 2012 at 12:56pm
Here is the final build I ordered today. I decided to stay with the X79/2011 over the Z77/1155 so I would have the potential to upgrade to a better CPU in the future if I end up needing it. I've been reading up on Intel Road maps for 2013 that show Q3 Ivy Bridge-E CPUs will be available for socket 2011. They also show socket 1150 replacing the 1155 socket.
I went with a single GTX 670 because I see soo many people in GW2 complaining about issues and performance on Crossfire and SLI setups. Even though the game does support it I've seen people claim they get more performance when they removed one of their cards. I'll wait for the bug's to get worked out and add a second GTX 670 later if I end up needing it.
Video Card(s): 1x NVIDIA GeForce GTX 670 2GB (PhysX) (FTW Overclocked EVGA)
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 28 Aug 2012 at 1:13pm
Congrats on a real nice rig.        No free t-shirt?
SpicierMire View Drop Down
  Quote SpicierMire Quote  Post ReplyReply bullet Posted: 28 Aug 2012 at 1:37pm
Enjoy your rig Awesome
Yet take it from me, most framerate issues --or the lack thereof-- in MMO's depend on the net code of the software, that is how well the communication layer is coded. SWTOr, for example, was a coding catastrophe, and the engine could barely handle 50 players in the same vicinity. I hope GW2 doesn't suffer the same fate!
  Quote Asangard Quote  Post ReplyReply bullet Posted: 28 Aug 2012 at 4:30pm
Congrats on your new rig. Cool  The free T-Shirt is a must.  It makes the build. Big%20Smile
Pirate Penguin View Drop Down
  Quote Pirate Penguin Quote  Post ReplyReply bullet Posted: 29 Aug 2012 at 6:08am
Even though I didn't post this, I gotta thank everyone for the advice since it's almost EXACTLY what I'm looking to have built soon!
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 29 Aug 2012 at 6:12am
Hi Pirate Penquin....  That is a real nice rig DBAndrew put together.
Good Luck.Big%20Smile
  Quote marccody Quote  Post ReplyReply bullet Posted: 29 Aug 2012 at 5:38pm
After further playing with the gtx 670 you will be just fine. :) i never have below 25 frames on world versus world with EVERYTHING (including supersample) maxed. The only game that my gtx has trouble running is shogun 2 but thats because shogun 2 is a monster. 20k units on the field max settings (well almost max) slows the computer down to like 25 frames :O
Edited by marccody - 05 Sep 2012 at 11:32pm
Tath View Drop Down
  Quote Tath Quote  Post ReplyReply bullet Posted: 03 Sep 2012 at 6:21pm
Originally posted by marccody
HIgh DBAndrew
This made my day, I've been researching rigs for the past week soley for the purpose to run GW2, and SWTOR. Thanks for posting this as I was leaning towards the ODE lvl 1 but was wanting to make sure it'd run the games fine.
  Quote DBAndrew Quote  Post ReplyReply bullet Posted: 10 Sep 2012 at 1:28pm
I've had my new DS system for about a week. Here is my performance experience so far.
i7-3820 OC @ 4.3Ghz
16GB DDR3
1 Geforce GTX 670 Evga OC FTW Edition.
240GB SSD - Corsair Force GT
Guild Wars 2, 1920x1080 on a 27" LED Samsung, All settings on High/Max.
I am getting 100-110 FPS out exploring and "questing" completing hearts, POI, Vistas. Depending on the zone, some have more terrain then others, I've seen it as high as 150 fps in some of the less complex areas.
In Lions Arch (Not overflow) by the Trading Post and Bank, too many players around to count I'm getting 70 - 80 fps depending on time of day(7pm-8pm MST) I would consider this prime time.
Public Event's in the 50-60 zones w/ about 20-30 players doing the same event, lots of combat and spells flying. I see 70-80 fps.
Dragon event's with The Shatterer or Tequatl. Tons of players show up for these zerg fest loot pinatas. Too many players to count but if I had to guess I'd say easy 100-150, once there was prob close to 200 players. During the 100-150 I'm seeing 30-35 fps, the one event that had close to 200 I was getting 20-30 fps. Lots of players complaining that their systems locked up and thus they got no credit and no loot for the fight. I felt fortunate that I got gold credit on all of these thanks to my new DS system. :)
World vs World (WvW), SM Castle, Inside on the Lord, big battle all 3 servers there, too many to count, it has to be 100+, prob closer to 200 players. I'm seeing swings in the range of 20-30 FPS. Depending on several factors, what way I'm facing, what I'm doing. It still feels semi smooth when I'm not moving. If I try to move or swing the camera around in a 180 there is some fps stutter. I've talked to other people with i5-2500k, and i7-2600k systems w/ 78xx a 79xx cards that are reporting around 30-40 FPS. Some of these people claim they never drop below 50-60FPS but this seems fishy. They must be running lower settings, lower resolution, or they are exaggerating. One guy I talked to with an i5-2500k and an AMD 7950 3GB claims he never goes below 50FPS
So I'm a little disappointed with the performance in these big 150+ player battles. Maybe my expectations are too high. I realize some of this is the game design, some is DX9. It is probably too much to expect 40+ FPS all the time. This is still a really great system and I am pleased with the increase in performance over my old system.
Supposedly there are known issues with the NVIDIA 301.42 WHQL drivers that the system came with. ArenaNet/GW2 shows a warning when I log in and says that the driver I'm running has known issues. They recommend running a beta 304.79 driver. I've searched and found mixed reviews on this beta driver. Some people say it is a big upgrade and claim 20-30% more FPS and/or it eliminates crash issues. Some people say it is no change for them. Some people even claim it ruined their video cards due to bad fan controls. So I'm not going to touch this beta driver. I will wait and once the next driver goes WHQL certified I'll see how the performance is then. If I'm still not pulling 40+ FPS in these big battles then I'll prob get another GTX 670 and see if SLI 670s can handle it.
Edited by DBAndrew - 10 Sep 2012 at 1:56pm
  Quote marccody Quote  Post ReplyReply bullet Posted: 10 Sep 2012 at 1:52pm
DB. Are you playing with everything max? (including supersampling). With everything max I get solid frames but not as good as yours. In lions arch when im moving around I get like 50. For big battles I get the same as you tho.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 10 Sep 2012 at 2:42pm
DBAndrew..   Thanks for the update.   I don't play GW2 but it should help those that do.   Have fun.
  Quote DBAndrew Quote  Post ReplyReply bullet Posted: 10 Sep 2012 at 3:09pm
Negative. It is on "Native". If I change that option to SuperSampling it drops by 10-15 fps.
Sorry I've also been playing with Reflections on "Terrain & Sky". I don't like being blinded by overly shiny armor. I think it looks cheesy. Other then those 2 settings everything else is on HIGH.
This page was generated in 0.1328125 seconds.
