Advice on High-End Build for Work/Personal use
Post Date: 2012-01-13
Dioxcyde View Drop Down
  Quote Dioxcyde Quote  Post ReplyReply bullet Topic: Advice on High-End Build for Work/Personal use
    Posted: 13 Jan 2012 at 6:23am
Chassis Model: Special Deal Hot Seller - Black OPS HailStorm Cryo-TEC Edition
Exterior Finish: - EXOTIC Black Smoke High-Gloss Paint Finish (HailStorm Chassis Only) <b></b>
Processor: Intel Core i7 Extreme Edition 3960X 3.3GHz (Six-Core) (Extreme Performance)
System Memory: 64GB DDR3 1600MHz Corsair Dominator DHX (High-Performance) <b></b>
Power Supply: 1200W Corsair Pro Gold Series (CMPSU-1200AX) (Dual/Triple/Quad SLI Compatible)
Expansion Bay: Internal Digital Media Card Reader (Black) <b></b>
Hard Drive Set 1: Operating System: 1x (250GB Solid State (By: Intel) (Model: 510 Series) (Extreme Performance) <b></b>
Hard Drive Set 2: Multimedia\Data: 2x (2TB Western Digital (7200 RPM) (Model: Black Edition) (SATA 6Gbps) <b></b>
Hard Drive Set 3: Backup\Misc.: 2x (2TB Western Digital (7200 RPM) (Model: Black Edition) (SATA 6Gbps) <b></b>
Optical Drive 1: Blu-Ray & DVD Writer/Reader (Burn + Play Blu-Ray & DVDs) (12x BD-R) (Lite-On iHBS112) <b></b>
Optical Drive 2: Blu-Ray & DVD Writer/Reader (Burn + Play Blu-Ray & DVDs) (12x BD-R) (Lite-On iHBS112) <b></b>
Internet Access: !PROMOTION: Killer 2100 (Optimized for Online Gaming) Lag and Latency Reduction <b></b>
Video Card(s): 4x SLI 4-Way (NVIDIA GeForce GTX 580 1.5GB (PhysX)  <b></b>
Sound Card: ASUS Xonar Essence STX Virtual 7.1 (PCI-Express Slot Based) <b></b>
Extreme Cooling: Digital Storm Cryo-TEC CPU System & Chipset + Triple Video Cards Liquid Cooling
H20 Tube Color: Blue Tubing with High-Performance Fluid (UV Lighting Reactive) <b></b>
Chassis Airflow: Upgrade Chassis With LED Performance Fans (Blue) (Up to 6 Fans) <b></b>
Internal Lighting: Internal Chassis Lighting System (Blue) <b></b>
Enhancements: Touch  V12XT Aerocool Temperature Display & Fan Controller (Requires Chassis Airflow Upgrade) <b></b>
Noise Reduction: Noise Suppression Package Stage 2 (Optimized Airflow & Fan Speeds with Noise Dampening Material) <b></b>
CPU Boost: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires Pro or Deluxe Series Motherboard)
Graphics Boost: FREE: Yes, Overclock the video card(s) as much as possible with complete stability <b></b>
OS Boost: FREE: Yes, Disable and tweak all of the non-crucial services on the operating system <b></b>
Windows OS: Microsoft Windows 7 Ultimate (64-Bit Edition) <b></b>
Recovery Tools: Advanced Recovery Kit (40GB Hard Drive Partition of Image With OS & Drivers) <b></b>
Office: Microsoft Office 2010 Pro (PC Attach Key PKC ) <b></b>
Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Medium) <b></b>
Priority Build: Please Prioritize: Ship Within Four Business Days After Order Is Successfully Processed <b></b>
Warranty: Life-time Expert Customer Care with 6 Year Limited Warranty <b></b>
(hoping DS can put Liquid Cooling on the 4th GPU)
This system will be used in conjunction with the following monitors & speaker:
3x Samsung S27A950D 27-Inch Class 3D LED Monitor
1x Corsair Gaming Audio Series SP2500 High-Power 2.1 PC Speaker System (CA-SP211NA)
This system is going to replace my Master work PC in my home office which is used for Monitoring my employees and doing all of my work dealing with 3D renders, CGI video rendering, Unity3D, UE3, CS5, and several other 3D software & Development tools. This will also be my main home PC which I will use for Gaming/movies/etc.
I was planning to make the purchase later today after speaking with DS over the phone, depending on peoples comments I still may do this or wait a couple days to figure out the perfect build. I am not very concerned with the cost, I just want to make sure everything will work properly, I'm getting the best possible outcome for my money, and that I'm not wasting money on anything(only thing I am not interested in having the *highest* level hardware in is my secondary drives as I need a fair amount of storage, I'm sure a nice 2-4 high end HDD setup will do nicely(would love some advice on this also) .
If all goes well I also plan to purchase 4-6 Development Workstations for our office building(for audio and 3D model/Animation design). (may ask for some advice on builds as well down the road)
I appreciate any constructive comments and advice, Thank you in advance everyone.
Edited by Dioxcyde - 13 Jan 2012 at 6:28am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 Jan 2012 at 12:13pm
Ok well you got bunch of issues, for example you don't want quad sli and even if you did it would not fit on that mobo.
lets back up, you want a system that can run 3d gaming across three 3d monitors?
  Quote FrankW Quote  Post ReplyReply bullet Posted: 13 Jan 2012 at 4:59pm
Hi Dioxcyde,
I just wanted to welcome you to the forum and urge you not to place your order until you get some feed back. DST4ME will give you some sound advise that will influence your configuration.
  Quote Dioxcyde Quote  Post ReplyReply bullet Posted: 13 Jan 2012 at 9:33pm
Spoke with some reps at Digital Storm, and got a new build
Order Contents:
- Digital Storm Desktop 339883 Quantity: 1 $11,132.00
- PROMOTION: 10% Discount of $1,237 Applied to Digital Storm Desktop 339883, Original Price $12,369 Quantity: 1 $0.00
- -- PROMOTIONAL LIMITED TIME BONUS DISCOUNT: $300 Quantity: 1 ($300.00)
- -- PROMOTIONAL LIMITED TIME 1 YEAR WARRANTY UPGRADE Quantity: 1 $0.00
- Add triple loop for Chipset By: John 1/13/2012 Quantity: 1 $250.00
- 4 th video card water block By: John 1/13/2012 Quantity: 1 $179.00
Chassis Model: Special Deal Hot Seller - Black OPS Syndicate Cryo-TEC Edition
System Memory: 32GB DDR3 1600MHz Corsair Dominator DHX (High-Performance)
Power Supply: 1500W Silverstone (Dual/Triple/Quad SLI Compatible) (Recommended)
Set 1 Raid Options: Configure HDD Set 1 to a Raid 0 Config - Stripe Performance (Requires Two HDDs)
Video Card(s): 3x SLI Triple (NVIDIA GeForce GTX 580 3GB (PhysX) (EVGA 03G-P3-1584-AR)
(they took out the Blu-Ray player because they said there are known issues with a Blu-ray player with this Mobo) any insight on that?
Also, doesn't seem to show on the order but there is a 4th Video card as well for Quad SLI (I know you said it wasn't compatible, they seemed to disagree, so I would love some further feedback on that first as well)
The System is for 3D Work, Rendering, and Game testing (Game Dev Company)
Edited by Dioxcyde - 13 Jan 2012 at 9:36pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Jan 2012 at 1:06am
Well quad sli gets out performed by tri sli, I would stick to that, if you are under lc then I guess you can fit all 4 cards.
Why the tec? you understand that the gpus will be under regular lc right?
drop the upgrad fans they are loud and not needed., fan controller will not controll all your fans and its temps are not accurate, there are better freeware out there for temps and etc that we all use.
the Syndicate case is cramped we have had tec owners change case to hailstorm due to crampy-ness of the case, I would also recommend you go with hailstorm, if you want led fans on the hailstorm let me know I will show you what kind to get.
for your lc remember its not a necessity but a luxury, you don't have to have it for good temps, but if you still want lc, I would go with regular lc on both cpu and gpus, and Instead of wasting money on fans and fan controller, instead as them to use XSPC "RX" series rad with Scythe gentle typhoon fans on them, this will give you better performance with practically no noise, vs the regular lc system DS will give you.
As far as I know non of the apps you use will utilize sli, so sli would be only for gaming and for that tri sli 580 will do best IMHO.
last the ssd, 320 has better 4k speeds then 510, if you want something that is faster than 320 then go with m4, I would not go with 510.
OH ya your uv tubes need uv lighting, you have chosen blue.
I have not heard anything about bd issues with mobo, but I have not been looking for it either, to be honest as you see from my avatar, I'm more of an evga person.
your thoughts.
  Quote Dioxcyde Quote  Post ReplyReply bullet Posted: 14 Jan 2012 at 12:44pm
[QUOTE=DST4ME]Well quad sli gets out performed by tri sli, I would stick to that, if you are under lc then I guess you can fit all 4 cards.
your thoughts.[/QUOTI plan to have the PC on 24/7 so that's the main reason for wanting TEC the money for that isn't a worry, so unless there is something better then it I'm not concerned. (not 100% sure what you mean by the the Gpus being under regular LC... does that setup mean it will be under regular LC and TEC?
I am going to request them putting an M4 as the main drive and I also switched my build up to a new setup. let me know what you think and thank you again for all the advice/help
Order Contents:
- Digital Storm Desktop 340040 Quantity: 1 $10,910.00
- PROMOTION: 10% Discount of $1,212 Applied to Digital Storm Desktop 340040, Original Price $12,122 Quantity: 1 $0.00
System Memory: 32GB DDR3 1600MHz Corsair Dominator DHX (High-Performance) <b></b>
Hard Drive Set 1: Operating System: - No Thanks <b></b>
Video Card(s): 3x SLI Triple (NVIDIA GeForce GTX 580 3GB (PhysX) (EVGA 03G-P3-1584-AR) <b></b>
Internal Lighting: Internal Chassis Lighting System (UV) (Creates Glowing Effect for H20 Tubes) <b></b>
Noise Reduction: Noise Suppression Package Stage 1 (Optimized Airflow & Fan Speeds Only) <b></b>
Memory Boost: Memory Fan Kit Only (Does not include memory overclocking service) <b></b>
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Jan 2012 at 6:55pm
I have my pc on 24/7, no tec here, somebody gave you bad info on needing tec with 24/7 use, no such need, your 24/7 use has no baring on what cpu cooler you use. Using a good air cooler like noctua will give you the same life span on your pc as tec, and even if not, your cpu will out live your pc with 24/7 use and noctua.
Problem will be tho if something goes wrong wtih tec, you have to be without your pc for over a month, cause you have to send the pc to DS and shipping back and forth alone takes 2 weeks at least.
I'm not telling you not to get it for money, I'm telling you not to get it cause you don't need it and also the simpler you keep things the less headache you will have, as I was always told growing up "K.I.S.S" (keep it simple stupid), less things = less things that can go wrong.
With regular lc at least if something goes wrong you can work on it yourself and swap parts, with tec you have to send it back.
Exactly, the tec is only for the cpu, your gpus are not under tec, they are under regular lc, as of right now tec is only for cpu.
very good on the m4.
Killer 2100 is pure waste of money, its difference if any at all is a needle in a haystack.
Noise Suppression Package is pointless specially if you request the rad and fans I mentioned, all the sound package does is take away from your air flow, but if you are using quiet fans like I mentioned, there is no reason to kill airflow.
Ask for vcore lower then 1.4 for your cpu oc.
drop the oc on gpus, its very mild here and you are gaining maybe 1 or 2 fps on each card, oced cards tend to fail faster.
with a good ssd windows boost yields zero gains, but if you need one of those services and don't know which it can turn into a headache.
for the os go with win7 cd/dvd, if the drive with your backup partition goes bad, then so is your back partition.
like to point out warranty is 6 years labor 4 years part, you pay shipping back and forth.
Now I like to speak about your cpu, you can go with 3930k and should not notice much difference if any at all, but I too like E chips, so I can't say I blame you but as long as you know its more preference to go with 3960x vs 3930k then it is performance.
keep in mind even with lc each gpu will still take about 2 pci slots, so with tri sli and sound card you have no more room for any other pci slots.(look at my config, it has a 4x classified and with 4 gpus on lc, I don't have any pci slots open at all and my board has 7 pci slots.
don't forget to ask for rad and fans I mentioned.
  Quote Dioxcyde Quote  Post ReplyReply bullet Posted: 15 Jan 2012 at 10:24am
@DST4ME would you mind setting up the best possible build to order and then just list what I should ask them to add in? you obviously know a lot about building a high end system and you know at this point money is not an issue, I just want the best without wasting. I would really appreciate it if you wouldn't mind. and then maybe just linking the build here.
Edited by Dioxcyde - 15 Jan 2012 at 10:25am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Jan 2012 at 12:29am
Here you go Ticket# 644156 --- $7,492 (To see this build click here)
System Memory: 32GB DDR3 1600Mhz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested)
Hard Drive Set 2: Multimedia\Data: 1x (2TB Western Digital (7200 RPM) (Model: Black Edition) (SATA 6Gbps)
Hard Drive Set 3: Backup\Misc.: 1x (2TB Western Digital (7200 RPM) (Model: Black Edition) (SATA 6Gbps)
Video Card: 3x SLI Triple (NVIDIA GeForce GTX 580 3GB (PhysX) (EVGA 03G-P3-1584-AR)
Extreme Cooling: H20: Stage 6: Sub-Zero LCS Dual Loop: CPU & Triple SLI/CrossFire Video Cards & Chipset
H20 Tube Color:Blue Tubing with High-Performance Fluid (UV Lighting Reactive)
Ask for vcore lower then 1.4 for your oc.
Ask them to use XSPC "RX" series rad for all your rads with Scythe gentle typhoon fans on them.
Now here you will endup probably with a single rad on cpu and triple rad on gpus, now if you want bigger rad for cpu, you need to look at having a triple rad in outside back like mine. Tho keep in mind lc is luxury so you don't need it to begin with.
Tell me what you think.
Edited by DST4ME - 16 Jan 2012 at 12:30am
