Advice on HydroLux Liquid Cooling Setup
Post Date: 2013-12-08
sreeraj.jay View Drop Down
  Quote sreeraj.jay Quote  Post ReplyReply bullet Topic: Advice on HydroLux Liquid Cooling Setup
    Posted: 08 Dec 2013 at 1:18am
Now I have selected dual SLI 780Ti.
In the future, I want to add another graphics card, as I will be moving onto 4K display.
So which is the recommended liquid cooling option at the moment?
H20: HydroLux Level 4: Digital Storm Exotic Custom Cooling System (3x Video Cards + CPU + Chipset)
OR
H20: HydroLux Copper: Digital Storm Copper Pipe Custom Cooling System (Video Cards + CPU + Chipset)
Confused
Please help.
That which doesn't kill you makes you stronger
RobZGames View Drop Down
  Quote RobZGames Quote  Post ReplyReply bullet Posted: 08 Dec 2013 at 1:35am
sh*t, wish i could help
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 08 Dec 2013 at 2:55am
Both options cool the same. The copper piping is only available on the Aventum and is for those wanting something unique and looks great.
Good luck.
  Quote fstcvc Quote  Post ReplyReply bullet Posted: 08 Dec 2013 at 7:09am
I guess you could have them pre-build a 3rd water block into your system with you later adding the additional card later but that's something you'd have to ask DS directly. You might only be able to have them do 2 GPUs and then send it back for an upgrade for the third GPU. Difference between your 2 options is the tubing used - option 1 is using soft tubing (various colors available), option 2 is using the polished copper tubing and is only available on the Aventum.
  Quote Alex Quote  Post ReplyReply bullet Posted: 08 Dec 2013 at 11:34am
If you are planning to do future upgrades including liquid cooling the GPUs, I suggest going with the regular non-copper version and order the exact cooling option for what you have configured. In the future, when you decide to upgrade, you can always get a water block, etc... or send it in to us for service.
  Quote sreeraj.jay Quote  Post ReplyReply bullet Posted: 18 Dec 2013 at 10:15pm
Thank you so much you guys Big%20Smile
I will go with the non-copper cooling version
You guys are the best Awesome
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 19 Dec 2013 at 3:08am
Our pleasure.
