Advice on Lynx level 3 build (AMD)
Post Date: 2019-05-24
Lostatsea View Drop Down
  Quote Lostatsea Quote  Post ReplyReply bullet Topic: Advice on Lynx level 3 build (AMD)
    Posted: 24 May 2019 at 8:41pm
Evening everyone :D I'm looking to get some feedback on my Lynx purchase if at all possible
Chassis Model: Digital Storm Lynx - Level 3 (MPN-2700-2060)
Processor: AMD Ryzen 7 2700 (8-Core) (Boost Up to 4.1 GHz)
Motherboard: ASUS / MSI (AMD X470 Chipset) (Up to 2x PCI-E Devices)
System Memory: 16GB DDR4 2666MHz Digital Storm Performance Series
Power Supply: 600W Digital Storm Performance Series (Supports up to an NVIDIA RTX 2070 GPU)
Optical Drive: - No Thanks
Storage Set 1: 1x SSD (240GB Digital Storm Performance Series)
Storage Set 2: 1x Storage (2TB Seagate / Toshiba)
Graphics Card(s): 1x GeForce RTX 2060 6GB (VR Ready)
Extreme Cooling: AMD Standard Factory Heat-sink and Fan
Chassis Fans: Digital Storm Performance Series (RGB Fans)
Airflow Control: - No Thanks
Branded Gear: - No Thanks
I'm trying to get over my dependency on Intel brand chips whils is why i went with the AMD build over the Intel version.. I think this pre-built option looks pretty nice and just wanted to see if anyone else had the same configuration
  Quote Cretae Quote  Post ReplyReply bullet Posted: 25 May 2019 at 3:24am
I don't have the same rig, but the Lynx 3 is an excellent value for money. The Ryzen 7 2700 is a very capable CPU that will perform well for several years. It is only about 5% off an Intel i7 8700 for a lot less money. The stock air cooler is excellent.
As long as you stick to 1080p monitor res, the RTX 2060 is THE price/performANCE gpu to have. Plus you get 16GB of RAM which is more than you need well into the future. If you're not looking to crush 2k gaming, it's the rig to have at a very nice price IMO.
