Advice on my build
Post Date: 2010-10-17
Howler View Drop Down
  Quote Howler Quote  Post ReplyReply bullet Topic: Advice on my build
    Posted: 17 Oct 2010 at 3:10pm
I am looking to get a new rig, my old one is 4 years old and struggles on most games nowadays. After reading and researching( the buying guide really helped a bunch), here is what i came up with  http://www.digitalstormonline.com/comploadsaved.asp?id=448872
I am looking to spend under 2500.
90 percent fps gaming, the rest pictures/internet surfing
I need a monitor, which would you recomend? I dont see any specs other than screensize on the list, is there a place to look I am missing? Any help would be greatly appreciated. Thx
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 17 Oct 2010 at 3:46pm
looks pretty good to me
for a monitor its really about what looks good to you, you are best off going to see them in person in my opinion, but just look for a monitor that is 21" or more and 1920x1080 with 5 ms or less, the rest is about how it looks to you
AmbientChong11 View Drop Down
  Quote AmbientChong11 Quote  Post ReplyReply bullet Posted: 17 Oct 2010 at 4:47pm
I would buy the monitor elsewhere. More selections and value. Don't forget, Black Friday is just around the corner.
Monitor response time - less than 5ms with a large viewing angle/contrast ratio.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 17 Oct 2010 at 10:12pm
Echo on the monitor selection. Please select a free game and a free t-shirt, or have them sent to me.  Cool
Coolermaster Storm Sniper
Intel Core i7 930 3.8GHz OC
EVGA X58 LE
6GB DDR3 1600Mhz Ram
750W Corsair
1TB HDD
1x ATI RadeonHD 5870 1GB
Noctua Dual 120mm
  Quote Howler Quote  Post ReplyReply bullet Posted: 18 Oct 2010 at 11:10am
Thanks for the help. Looks like i can save a few bucks by buying a monitor elsewhere, would it be worth it to take the savings and upgrade the soundcard? I have to use headphones since the wife says it sounds like a war going on if i dont, would the better soundcard carryover to them, or is it mostly for speaker improvement? Thanks again
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 18 Oct 2010 at 11:44am
soundcard inproves any sound output as long as your speakers/headphones are good enough quality to take advantage
