Advice on my build
Post Date: 2010-10-18
StraightNightmare View Drop Down
  Quote StraightNightmare Quote  Post ReplyReply bullet Topic: Advice on my build
    Posted: 18 Oct 2010 at 11:16am
Hi,
Computer Usage- 80% Gaming / 20% Movies (nothing else)
Games 3D ,civilization,Diablo2011, etc
Movies , Blue Ray /DVD
Hours on game per day between 6 &12
Video Connecting to LCD TV
Audio 5.1 connecting to Receiver
Budget $4300
Please take a look at my build and let me know what you think. I would greatly appreciate any suggestions modifying the build.
Thank you for your help
STR8
Edited by StraightNightmare - 18 Oct 2010 at 12:18pm
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 18 Oct 2010 at 11:46am
welcome to the forums, take a minute to read over the guide in my signature which is packed full of information including the answer to each of your questions
6 and 12 hours straight per day? geez.
  Quote StraightNightmare Quote  Post ReplyReply bullet Posted: 18 Oct 2010 at 12:23pm
Thank you ender for your reply.
What did you think of my build?
STR8
Edited by StraightNightmare - 18 Oct 2010 at 12:26pm
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 18 Oct 2010 at 12:39pm
i would change lots of things, all noted in the guide which is based completely on the best gaming bang for your buck. if you dont feel like reading it all, you can skip to the bottom that will list builds per budget
and to answer your GPU question, i would definitely take dual 480s over anything ATI can currently offer
  Quote StraightNightmare Quote  Post ReplyReply bullet Posted: 18 Oct 2010 at 1:29pm
Thanks
I'll take a look at it.
ghost View Drop Down
  Quote ghost Quote  Post ReplyReply bullet Posted: 18 Oct 2010 at 1:56pm
eww you went with 2 5970's thats quad crossfire btw...might run into ALOT of issues going that route, even with 1 card my nabor has replaced his 5970 3 times since hes got it
and I hear the led fan upgrades run loud, might want to check on that. and I see you selected window modification, but im almost possitive your case allready comes with a side window with fan, so that option wouldnt work for your case choice.
one thing ive noticed about DS setup, unlike ibuypower and other sites it doesnt tell you when you run out slots, or something with your setup does fit etc etc. Would be nice to see that feature added to the site. I know im just an your average joe and ive had to go and research each and every peice before selecting what I wanted.
Edited by ghost - 18 Oct 2010 at 2:06pm
venom View Drop Down
  Quote venom Quote  Post ReplyReply bullet Posted: 24 Oct 2010 at 11:22pm
I'd recommend this: http://www.digitalstormonline.com/comploadsaved.asp?id=451121
MagiK View Drop Down
  Quote MagiK Quote  Post ReplyReply bullet Posted: 25 Oct 2010 at 11:58am
Ghost yeah it woul dbe nice to know when you have run out of Slots....AND also run out of PCIe lanes.
