Advice on my build
Post Date: 2011-09-21
againstempire View Drop Down
  Quote againstempire Quote  Post ReplyReply bullet Topic: Advice on my build
    Posted: 21 Sep 2011 at 8:07pm
Hey here is my build with a budget of 4k is this a good set up to run 1920x1080
saved ticket #598910
System Memory: 8GB DDR3 2400Mhz Corsair Dominator GT (Model: CMT8GX3M2A2133C9)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 580 1.5GB (PhysX) (Overclocked EVGA Edition)
Extreme Cooling: H20: Stage 4: Sub-Zero LCS Cooling System: CPU Only
Internal Lighting: Internal Chassis Lighting System (White)
Edited by againstempire - 21 Sep 2011 at 8:08pm
eddiebove View Drop Down
  Quote eddiebove Quote  Post ReplyReply bullet Posted: 21 Sep 2011 at 8:39pm
If you're only using one monitor at that res I REALLY don't think you'd need two 580's, maybe one, if anything just one 570 with the possibility of going sli with that in the future if you find you really need to
  Quote againstempire Quote  Post ReplyReply bullet Posted: 21 Sep 2011 at 9:06pm
so two gpus are for two monitors?
  Quote eddiebove Quote  Post ReplyReply bullet Posted: 21 Sep 2011 at 9:18pm
Well no just that multiple monitors usually require sli in that two monitors need a lot of power from the video card(s) to both be running together
Vlad View Drop Down
  Quote Vlad Quote  Post ReplyReply bullet Posted: 21 Sep 2011 at 9:41pm
i think the system is fine, if u want a high end gaming pc. i am pretty sure if u get sli 570 or just go with ur build. u not gonna need to upgrade ur system for atleast 3-4 years, if u continue to use that monitor, or even of u get a second same size monitor ull be fine for sure! :)
Edited by Vlad - 21 Sep 2011 at 9:42pm
  Quote againstempire Quote  Post ReplyReply bullet Posted: 21 Sep 2011 at 9:49pm
so with all those specs I will be able to play games at pretty good settings?
Vlad View Drop Down
  Quote Vlad Quote  Post ReplyReply bullet Posted: 21 Sep 2011 at 9:59pm
haha bro.. u dont know the power of sli 580! :) but ye pretty much. bf3, guild wars 2, gear wars 3 and diablo 3, u can max them out for sure! but if u add a second monitor u should still max the setting out for those games but maybe not for others that will come out in a few years. and dont take my word yet... but u should still wait till the pros confirm. couse i might mistaken about something, but its not too big tho, ik for sure that even sli 570 will max out those games on ur res, but the thing that makes me wonder is a second monitor. but dont worry to much, u should expect similar answer from the pros or even better. i heard that even 1 570 can max out those games on that resolution, maybe ur over doing it? i cant think right now, its night! lol :)
Edited by Vlad - 21 Sep 2011 at 10:07pm
  Quote againstempire Quote  Post ReplyReply bullet Posted: 21 Sep 2011 at 10:08pm
whats the point of a second monitor anyway??
  Quote eddiebove Quote  Post ReplyReply bullet Posted: 21 Sep 2011 at 11:01pm
multi-tasking, like gaming and watching youtube or something lol, there's no way you'd need to waste your money on two 580s... one should be fine for a long time and if anything just buy a new one in the future (cause it'll be cheaper anyway) and install it yourself, which is completely easy
Dranzogger View Drop Down
  Quote Dranzogger Quote  Post ReplyReply bullet Posted: 21 Sep 2011 at 11:54pm
570s in SLI is enough for 1920x1080, maybe take a look at ode 3?
  Quote againstempire Quote  Post ReplyReply bullet Posted: 22 Sep 2011 at 12:19am
I would get the ode 3 but I would like to have the option to upgrade or sli later if i do decide to go with just one 580 and i do like the luxury of LC is sli 570s better then one 580?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 22 Sep 2011 at 1:00am
Your ram and sli 580s are overkill all you need for that res and games like bf3 is sli 570.
Here you go Ticket# 598988 --- $2,861 (To see this build click here)
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 22 Sep 2011 at 1:02am
SLI'd 570s would be better than one 580, yeah, but that's overkill for 1 monitor at 1920x1080. At 2560x1600, that's reasonable, but I'd say stick with a solo 580.
I believe that motherboard can support 2 card SLI, not sure about triple.
The ODE3 would do you well, but if you wanted to hit your budget on a normal build, you could easily stick CPU/1 GPU liquid cooling in your original build. Also, that original build should be hitting higher processor and graphics clocks and therefore performance.
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote againstempire Quote  Post ReplyReply bullet Posted: 22 Sep 2011 at 1:05am
is there anything wrong with overkill such as sli 580s on 1920x1080 and the RAM?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 22 Sep 2011 at 1:07am
let me put it to you like this, I can come in the middle of the night and replace the ram with the ram in my config, and sli 580 with sli 570 and you would never notice the difference the next morning if nobody told you, so in short, you are throwing your money away.
you also don't need the lc, as you can see in my config its on air.
Edited by DST4ME - 22 Sep 2011 at 1:08am
  Quote againstempire Quote  Post ReplyReply bullet Posted: 22 Sep 2011 at 1:14am
ok well I see what you mean by the ram and gpus but with the lc is there anything wrong with having it? I kinda like the luxury of the lc
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 22 Sep 2011 at 11:54am
Thats what lc is, luxury, but if that is what you are getting for it then go for it, its a nice luxury to have
  Quote againstempire Quote  Post ReplyReply bullet Posted: 22 Sep 2011 at 9:15pm
now with lc whats the maintenance that needs to be done or is there even any maintenance that needs to be done??
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 23 Sep 2011 at 3:53am
once a month or once every 5 months you may need to add fluid to the reservoir, which is very easy.
once every 3 years its best to flush the system.
bobels View Drop Down
  Quote bobels Quote  Post ReplyReply bullet Posted: 24 Sep 2011 at 6:51am
well i got a PC from Build your Box with 2 GTX 580s its works really well!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 24 Sep 2011 at 8:11pm
of course but if you res is at 1900 x 1200 or lower, you would get the same performance with sli 570 and you would not notice the difference.
