Advice request for a Second Gaming Machine
Post Date: 2015-02-10
Gnicky View Drop Down
  Quote Gnicky Quote  Post ReplyReply bullet Topic: Advice request for a Second Gaming Machine
    Posted: 10 Feb 2015 at 10:34am
Hello DS Friends. I am planning to gift my current DS Rig to my son after my next DS purchase and although I was thinking end-of-year, I am considering buying something like the config below now instead, swapping out the graphics card with my 780ti Classified and using my 512 SSD. I would then plan to upgrade the 780 at some point. I am currently gaming at 3440x1440 with good results and expect my current card is almost as good as any single GPU card right now.
So here are my questions:
1 - overall impressions or any suggestions for tweaks?
2 - will I be able to adjust my individual fan speeds with the included software, say to ensure positive pressure?
3 - are there any upgrades, including soon-to-be-released hardware that would give me better longevity or reliability?
4 - for DS, when is the next planned sale for price/warranty extension? (black Friday is a long way off
<$3K, but really just looking for good value.
Gaming at 3440x1440
FPS and Open World Gaming, FC4, Metro Last Light, Dying Light, COD...
Reliability & Longevity - Able to use as multimedia PC - Ready for 4K Gaming with Vid Card Upgrade
Configuration Code: 1146599
Total Price with Instant Savings: $2,489.00
Direct Load URL: https://www.digitalstormonline.com/configurator.asp?id=1146599
Chassis Model: Special Deal Hot Seller - Corsair Carbide Series Air 540
Motherboard: ASUS SABERTOOTH Z97 MARK2 (Intel Z97 Chipset) (Military-Grade TUF Components)
System Memory: 16GB DDR3 1866MHz Corsair Dominator Platinum DHX (Extreme-Performance)
Power Supply: 750W EVGA SuperNOVA
Optical Drive: ASUS Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Model: BC-12B1ST)
Storage Set 1: 1x SSD (256GB Samsung 850 PRO)
Storage Set 2: - No Thanks
Graphics Card(s): 1x NVIDIA GeForce GTX 970 4GB (EVGA ACX Cooler Edition)
Extreme Cooling: H20: Stage 2: Corsair H110 280mm Radiator Liquid CPU Cooler (Extreme-Performance Edition)
Internal Lighting: Digital Storm RGB LED Lighting System (Requires Thermal Management Control Board & Software)
Portable Gaming: - No Thanks
Branded Gear: - No Thanks
Edited by Gnicky - 11 Feb 2015 at 6:01pm
Pacesetter View Drop Down
  Quote Pacesetter Quote  Post ReplyReply bullet Posted: 11 Feb 2015 at 8:10pm
MAXIMUS VII FORMULA/WATCH DOGS motherboard is one to check out.
http://www.asus.com/us/Motherboards/MAXIMUS_VII_FORMULAWATCH_DOGS/
Not sure if DS has it but they may be able to get it for you if they don't.
I saw they had the maximus VII hero listed.
Since you are planning on using your video card and SSD, this is the only thing I'd look at.
Good build. : )
Vanquish II Ultimate.
michaeljhuman View Drop Down
  Quote michaeljhuman Quote  Post ReplyReply bullet Posted: 11 Feb 2015 at 8:58pm
My ASUS mobo, has something called Fan Expert, that can control fans to some extent.
  Quote Gnicky Quote  Post ReplyReply bullet Posted: 13 Feb 2015 at 9:25am
Thank you for your feedback. I was hoping to hear back on the operations of the Thermal Management control in this application, but I do not see many people ordering it. I'll plan to contact DS directly to follow up on the fan control options.
I am also strongly considering bumping up my build for an X99 platform. Looks to be about 25% more, likely getting more benefits a couple of years out.
The X99 build would look something like this (possibly saving a few more bucks going down to a 780 for my son...
Processor: Intel Core i7 5820K 3.3GHz (Six-Core) (Unlocked CPU)
Motherboard: ASUS X99-E WS (Intel X99 Chipset) (Workstation Class)
System Memory: 16GB DDR4 2666MHz Corsair Dominator Platinum DHX (Extreme-Performance)
Edited by Gnicky - 13 Feb 2015 at 9:27am
  Quote michaeljhuman Quote  Post ReplyReply bullet Posted: 13 Feb 2015 at 8:43pm
Only one drive, and a 256 only?
Are you adding your own drive(s)?
  Quote Pacesetter Quote  Post ReplyReply bullet Posted: 13 Feb 2015 at 10:28pm
For me, I'd add a 1TB HDD but that is preference. I assume you are still planning on using your SDD.
The motherboard offers plenty of expandability and the CPU even though a workstation class has been rated high for overclocking and gaming.
I like the dual chamber design of the case for positive air flow and it keeps the P/S away from the SDD cages. Plenty of room for expansion here, also. The case also gets high reviews.
3 fans included and the liquid cooling should be quite adequate.
Looks like a solid build to me, expandable for future needs.
