Aerocool Dead Silence Case Fans
Post Date: 2014-12-09
  Quote FrankW Quote  Post ReplyReply bullet Topic: Aerocool Dead Silence Case Fans
    Posted: 09 Dec 2014 at 9:25am
Has anyone use any of the Aerocool Dead Silence Case Fans? They have plastic and rubber construction. I don't know how that effects their longevity. They have great specs. That DS on the hub would look great in a DS computer.
140mm Fan
RPM/12v = 1000 RPM
CFM/12v = 64.8 CFM
dba/12v = 14.2 dba
RPM/7v = 700 RPM
CFM/7v = 39.8 CFM
dba/7v = 10.8 dba
What do you think?
Edited by FrankW - 09 Dec 2014 at 9:28am
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 09 Dec 2014 at 1:51pm
I did research on those fans and i hear they move lots of air and are great fans
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 09 Dec 2014 at 1:56pm
If those dba specs with the cfm airflow hold up then they are a fan to look into.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 09 Dec 2014 at 2:07pm
I looked around and I couldn't find the 140 fans with these specs. The 140 Aerocool fans I found had a 12v rpm of 1500. Of course the dba readings were also higher. They do have a 7 volt pin you can install that reduces the voltage to 7v and around 1000 rpm. They have a 100,000 hour MTBF. The be quiet fans that had close dba readings have a 300,000 hour MTBF.
