AIO Cooler?
Post Date: 2019-03-03
BravoActual View Drop Down
  Quote BravoActual Quote  Post ReplyReply bullet Topic: AIO Cooler?
    Posted: 03 Mar 2019 at 11:42am
Any suggestions for an AIO cooler for an i9 9900k on a ASUS ROG Strix Z390-H Gaming MOBO in a Lumos case? My rig will be here on March 6th, and I originally went with a 140mm AIO (was restricted by budget). I plan on buying a new AIO today but just want to make sure it will fit etc. Was looking at a 280mm from Corsair. Thanks in advance for any suggestions.
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 03 Mar 2019 at 11:49am
Corsair 280mm H115i Pro.....In Lumos case it could fit top or front, but likely front would be a skosh roomier fit.
thedemoncowboy View Drop Down
  Quote thedemoncowboy Quote  Post ReplyReply bullet Posted: 03 Mar 2019 at 11:51am
We have the same build build! Should just get the one from DS!
Psyoshi View Drop Down
  Quote Psyoshi Quote  Post ReplyReply bullet Posted: 03 Mar 2019 at 12:01pm
Go with the 280mm Corsair H115i, trust me it is worth it plus it comes with a 5 year warranty. Don't go with the DS branded one.
  Quote BravoActual Quote  Post ReplyReply bullet Posted: 03 Mar 2019 at 1:53pm
Just purchased the Corsair H115i RGB Platinum 280mm AIO. Thanks guys.
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 03 Mar 2019 at 3:48pm
Biggest radiator your case will take, so dependable max cooling for you. Should work great!   Let us know how it goes.....
WestmartBC View Drop Down
  Quote WestmartBC Quote  Post ReplyReply bullet Posted: 04 Mar 2019 at 2:26am
According to the product page the 280 will only fit on the top.
