Air cooling questions
Post Date: 2008-06-10
joeschmo View Drop Down
  Quote joeschmo Quote  Post ReplyReply bullet Topic: Air cooling questions
    Posted: 10 Jun 2008 at 7:26pm
I am looking to buy from you guys and i just have a few config questions on some cooling and overclocking info.
These would be with either the 850si or 950si cases:
I would probably go air cooled. Is stage 3 worth the upgrade or should i stick with level 2. Is stage 3 alot louder than two? What are the differences?
I would also probably go dual core(e8400/8500). About how much of an increase in cpu speed could i get if i paid to get mine overclocked?
Also would a 750w power supply be enough (hoping to pick up a gtx 280 when its released. just one though)
And finally between the two cases im guessing the 850si is cooler but louder. And im looking to keep my rig relatively quiet. So ill probably go with the 950si.
I'm looking to keep my rig in the high 1ks without a graphics card. Any other advice on mobo's and ram would be greatly appreciated.
SunfighterLC View Drop Down
  Quote SunfighterLC Quote  Post ReplyReply bullet Posted: 10 Jun 2008 at 7:53pm
Stage 3 is great for large cases, I have a Cosmos S with stage 3. Its pretty good at keeping everything cool. Its definally louder then my last computer though thats for sure. Not enough to be annoying, but enough that you know its there.
E8500@ 4.03Ghz
XFX 790i Ultra
1000W Corsair HX
2 280 GTX EVGA FTW
4GB OCZ Reaper 1800Mhz
250-80-300GB VR HD
Logitech Z-2300 2.1 Speakers
Asus Xonar 7.1
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 10 Jun 2008 at 11:45pm
850 is a better air cooler, imo
with the 850, stage 3 is 110% worth it, you are getting way more than an $80 value
theres never a garentee with overclocking, id suggest quad core, personally, but you can hope for a 20-40% increase
not sure about the new card, youll have to look that up
if youre concerned with keeping things quiet the 750 may not be a bad choice, especially if you are trying to stay under 1k
my personal choice would be an asus max / 2gb @ 1066, but keeping the thing under 2k will be tough to stay on par with the GPU youre looking at
  Quote joeschmo Quote  Post ReplyReply bullet Posted: 11 Jun 2008 at 12:08am
if i were to go quad core which chip would you recomend?
and thanks alot for your help so far!
Edited by joeschmo - 11 Jun 2008 at 12:08am
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 11 Jun 2008 at 12:18am
9450 hands down
  Quote joeschmo Quote  Post ReplyReply bullet Posted: 11 Jun 2008 at 11:45am
K i am able to keep the whole thing under 2000 without a graphics card.
850si case
750w powersupply
quad q9450
780i sli motherboard
2ghz corsair ddr2 1066mhz Dominator
320gb WD
Air Cooling Stage 3
And: Overclock my cpu with complete stability
I cant go any more expensive than that, but should i change any of these options to save a few bucks in one spot and spend a few more in another?
Tyler Lowe View Drop Down
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 11 Jun 2008 at 1:27pm
That's a very strong setup. I wouldn't change anything.
kclemens View Drop Down
  Quote kclemens Quote  Post ReplyReply bullet Posted: 11 Jun 2008 at 3:17pm
You could always take off any overclocking if you have it and learn on your own if you really want to save.  I wouldn't recommend that though.
MikeMaravani View Drop Down
  Quote MikeMaravani Quote  Post ReplyReply bullet Posted: 11 Jun 2008 at 4:28pm
what about the new Thermaltake DuOrb fan? I heard its great, but it can block the Ram slots or the PCI express slots. and its quite as hell
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 11 Jun 2008 at 11:29pm
i wouldnt change anything, but make sure if you OC the cpu you do the RAM too or youll be cheating yourself out of some real power
  Quote joeschmo Quote  Post ReplyReply bullet Posted: 12 Jun 2008 at 12:02am
k thanks alot guys!
I think this is definitely the best i can do with my budget.
I am very very pleased! Thanks again for your help
Kliebor2 View Drop Down
  Quote Kliebor2 Quote  Post ReplyReply bullet Posted: 14 Jun 2008 at 8:01am
I do like the configuration choices they offer here at Digital Storm, a lot of great stuff here :)
It is hard to go wrong especially since after you ordered if you did make any mistakes one of the sales guys calls you to correct the issue with the config.
Dual PNY OC2 GTX 560Ti
8 Gigabytes DDR2/800
