Air Cooling vs Liquid Cooling
Post Date: 2008-12-09
MikeMaravani View Drop Down
  Quote MikeMaravani Quote  Post ReplyReply bullet Topic: Air Cooling vs Liquid Cooling
    Posted: 09 Dec 2008 at 12:33pm
I was going through the "Make your own build" and I got down to the H2O cooling. I really like air so far, but I want something new. I just don’t know the pros & cons of H2O. Any help would be appreciated. My ticket number is 215065.
Also I was hoping that I could save the $97 by down grading the Intel Core 2 Quad Q9550 2.83GHz  to a Intel Core 2 Quad Q9300 2.5GHz. I would OC them both but I dont know how much a difference in speed there will be. Thanks in advance.
XpubuX View Drop Down
  Quote XpubuX Quote  Post ReplyReply bullet Posted: 09 Dec 2008 at 12:49pm
I think you would be better off and more future proof with i7 on air as opposed to core 2 quad on liquid. H20 is quiet keeps things cooler. You will at somepoint have to add more liquid. Air is noisier and does not cool as good although as long as you dont choose the stock fan you should be able to reach a nice OC.Liquid does OC better but not by a huge amount. If you choose the haf case it will be a somewhat noisy system regardless. Also gpu can be noisy if you turn the fan speed up which I recommend.
Edited by XpubuX - 09 Dec 2008 at 12:54pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 09 Dec 2008 at 4:15pm
Liquid cooling is the way to go
I highly suggest you go with liquid cooling, its much more quite, cooler, faster, stable.
I don't know anybody that knows what they are doing and has a 4.0GHz oc or higher with any problems. In this case DS takes care of everything for you, so you don't need to know nothing
this is a much better system
here you go Ticket# 215109 --- Price: $2529 (To see this build click here)
System Memory: 6GB DDR3 1333MHz OCZ
Power Supply: 750W Corsair TX (Dual SLI Compatible) (Silent Edition)
Card Reader: - No Thanks
Hard Drive Set 1: Operating System: 500GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Video Card: 1x NVIDIA GeForce GTX 260+ 896MB (216 Streams) (Includes PhysX Technology)
Liquid Color:UV Green: Glowing Non-conductive High-Performance Fluid (Requires H20: Stage 3 & UV Lighting)
LCD Display: - No Thanks
Priority Build: - No Thanks
this system is much better then the one in your ticket, you can upgrade this in the future to next round of cpus and this pc is good for atleast next 4 years.
its overclocked, and much faster and better then the q9550
Edited by DST4ME - 09 Dec 2008 at 4:16pm
