air/hyrdolux liquid cooling
Post Date: 2013-11-03
Dragonstorm View Drop Down
  Quote Dragonstorm Quote  Post ReplyReply bullet Topic: air/hyrdolux liquid cooling
    Posted: 03 Nov 2013 at 3:09pm
What is the difference in temp for the video card and chipset
the config is 882277. It seems like a lot of high end machines use advanced liquid cooling. So I'm wandering if the computer will overheat down the road.
From what I've read video cards with the stock aircooler (no liquid cooling) can get around 90F
RIP XBOX360
  Quote Alex Quote  Post ReplyReply bullet Posted: 03 Nov 2013 at 4:07pm
Your configuration looks great. You don't need liquid cooling, it's just a luxury option for customers. The GTX TITAN and other new NVIDIA graphics cards run fairly cool, they will have no issues under even the most extreme gaming sessions.
  Quote Dragonstorm Quote  Post ReplyReply bullet Posted: 03 Nov 2013 at 4:45pm
Thanks you're always so helpful Alex.
RIP XBOX360
  Quote Alex Quote  Post ReplyReply bullet Posted: 03 Nov 2013 at 5:24pm
You're very welcome!
Meller View Drop Down
  Quote Meller Quote  Post ReplyReply bullet Posted: 03 Nov 2013 at 6:11pm
Liquid cooling is more so an option if you wish for a much quieter system.  Plus if you're going to be OC your CPU and you have multiple video cards that you're also OC... liquid cooling is a better option.  All of those OC's will run hotter, and while air cooling can keep them nearly just as cool, it will be so much louder.  So liquid gives you more head room for OC, keeps your temps way down, and remains much cooler.
