Air or Liquid Cooling?
Post Date: 2010-02-13
firebolt059 View Drop Down
  Quote firebolt059 Quote  Post ReplyReply bullet Topic: Air or Liquid Cooling?
    Posted: 13 Feb 2010 at 11:15pm
What should i have for my Extreme Cooling? Air or Liquid? Also, if i have Dual ATI 5870 IN Crossfire, will i need the H20: Stage 6: Sub-Zero LCS Dual Loop: CPU & Dual SLI/CrossFire Video Cards upgrade? if not, what should i have? Thanks in advance!
Raif View Drop Down
  Quote Raif Quote  Post ReplyReply bullet Posted: 13 Feb 2010 at 11:45pm
whats your room temp summer/winter if it is about 75 deg then you need LC if not no unlees u get stage 2 oc. you want stage 3 or 6 if you choose LC. frost chill and subzero.
its all up to you weather u get it or not. just warning you a LC system costs more and you also need to maintain it.
add fluid as needed
checking the flow
a flush every few years
all on top of the air maintenance since you still have fans
2.5 Ghz Core duo
Nvidia 9500 gt
3 gb 1033 Mhz ram
[email protected]
  Quote firebolt059 Quote  Post ReplyReply bullet Posted: 14 Feb 2010 at 12:44am
bump
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Feb 2010 at 12:47am
why do you need LC?
you don't need it, if you prefer to have it then yes the option you chose is correct if you have 2 x 5870.
MasterAssassin View Drop Down
  Quote MasterAssassin Quote  Post ReplyReply bullet Posted: 14 Feb 2010 at 1:06am
Originally posted by DST4ME
why do you need LC?
So should he need Air cooling then? what would Liquid cooling be used for?
Edited by MasterAssassin - 14 Feb 2010 at 2:49am
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 14 Feb 2010 at 11:23am
What's your case, do you have any overclocking, how hot is your room, how hot does your current computer operate, what are your current computer cooling components?
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
philiporphillip View Drop Down
  Quote philiporphillip Quote  Post ReplyReply bullet Posted: 14 Feb 2010 at 6:35pm
why do you need LC?
liquid cooling is needed when you want to go extreme on overclocking, or to just simply show-off.
Digital Storm
haf 922
i7-920 oc'd @ 3.6 ghz (1.28v)
evga x58 le edition sli
cooler master v8
6 gb ddr3 1600 mhz mushkin
evga nvidia geforce gtx 295 co-op edition
1000w corsair hx
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Feb 2010 at 1:14am
why do you need LC?
LC is for people who want to push their parts to extreme limits or just want lower temps then air.
