Air or Liquid Cooling?
Post Date: 2010-02-14
firebolt059 View Drop Down
  Quote firebolt059 Quote  Post ReplyReply bullet Topic: Air or Liquid Cooling?
    Posted: 14 Feb 2010 at 1:40pm
i know that i have made a post like this, but i wanted to know what my cooling should be for this system.
This is my current system so far:
Chassis Model: Cooler Master HAF 932 (Black OPS Edition)
Motherboard: ASUS Rampage II Extreme (Intel X58 Chipset) (Supports Triple SLI or CrossFire)
System Memory: 6GB DDR3 1600MHz Corsair Dominator with DHX Extreme Edition
Video Card: 2x CrossFire Dual (ATI Radeon HD 5870 1GB)
Boost Processor: Stage 2: Overclock the processor between 4.0GHz to 4.2GHz (Requires H20 Cooling Upgrade)
I would like it to air cooled, so is the Noctua NH-D14 Extreme Performance Cooler good for this config?
Edited by firebolt059 - 14 Feb 2010 at 1:43pm
philiporphillip View Drop Down
  Quote philiporphillip Quote  Post ReplyReply bullet Posted: 14 Feb 2010 at 1:44pm
you need liquid cooling since you selected stage 2 overclock.
i would just select stage 1 overclock with air cooling like the v8 or noctua.
Digital Storm
haf 922
i7-920 oc'd @ 3.6 ghz (1.28v)
evga x58 le edition sli
cooler master v8
6 gb ddr3 1600 mhz mushkin
evga nvidia geforce gtx 295 co-op edition
1000w corsair hx
  Quote firebolt059 Quote  Post ReplyReply bullet Posted: 14 Feb 2010 at 3:27pm
DST4ME, what do you think about this?
Herniter View Drop Down
  Quote Herniter Quote  Post ReplyReply bullet Posted: 14 Feb 2010 at 4:56pm
Allow me to assist you.
Originally posted by DST4ME
what resolution are you gonna be gaming at?
are you trying to build yourself?
if you are looking at other builders, let me let you know that just because you think you are seeing the same parts here as some place else, they are not the same.
Res: 1900 by 1200
i was building it on the site, if that is what you mean,
i was not looking at other companies stuff, just like you, i think DS is the best.
ya sorry about that snow DST4ME. but ill play Crysis and GTA 4 and Modern Warfare 2. Can you update that config for me? thanks
@ 1900 x 1200 with 2 x 5870 with highest settings and 2x aa you should get between 50 to 60fps which is what you want.
why do you need LC?
you don't need it, if you prefer to have it then yes the option you chose is correct if you have 2 x 5870.
and
last time I recommended rampage asus made me look like a dumbass to all the people that got it.
change your mobo to evga 3x sli or the LE.
don't go with asus, if you like a few more pci lanes then go with evga LE.
the techs will tell you that evga has better support, which is one of the reasons why I like evga.
Edited by Herniter - 14 Feb 2010 at 11:38pm
  Quote philiporphillip Quote  Post ReplyReply bullet Posted: 14 Feb 2010 at 6:31pm
Edited by philiporphillip - 14 Feb 2010 at 6:58pm
Digital Storm
haf 922
cooler master v8
1000w corsair hx
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Feb 2010 at 12:44am
don't like the mobo
no need for the more expensive ram
psu is not good
not sure if we discussed whether you need 2 x 5870.
you have chosen factory cpu cooler which is the lowest cooler possible, then you piced stage 2 oc.
1. you don't need stage 2 oc
2. you can't do stage 2 oc unless you have stage 3 LC or higher.
Noctua NH-D14 is a great cooler but DS won't do stage 2 with it, and as I said you don't need stage 2.
if you want xp mode go with win7 pro.
Edited by DST4ME - 15 Feb 2010 at 12:49am
  Quote firebolt059 Quote  Post ReplyReply bullet Posted: 15 Feb 2010 at 10:16am
don't like the mobo
psu is not good
What Motherboard should i have then? Why dont you like the Asus i picked out?
What RAM should i have then?
What psu should i have with this then?
i will play Crysis and GTA 4 and Modern warfare 2 with the Dual 5870 in Crossfire
Yeah i messed up on the cooler, i meant the Noctua NH-D14
  Quote firebolt059 Quote  Post ReplyReply bullet Posted: 15 Feb 2010 at 2:05pm
bump
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Feb 2010 at 2:44pm
asus is not good anymore, their tech support sucks, that board has nothing for you gain over a evga, I have configed a few builds for you by now, so from them you know what board to get.
for ram just pick the regular 6GB DS ram.
for psu depends on your parts, but a 1000w corsair will do tri sli for you, again I have configed enough systems for you to look at and see which psu I had picked each time.
crysis the 2 x 5870 will help you, gta4 needs a single card with over 1.5GB of ram otherwise you will run out of memory, and no the 5970 and 295 do not have that much ram since they are not single cards, they are in internal sli/cf.
just keep in mind you are not gonna be able to max them out with high aa, even with 2 x 5870.
