Air vs Liquid ::Cooling Collision::
Post Date: 2009-05-09
Teckno View Drop Down
  Quote Teckno Quote  Post ReplyReply bullet Topic: Air vs Liquid ::Cooling Collision::
    Posted: 09 May 2009 at 5:14am
Just like to say hello to everyone, I am fairly new here ^^.
Im interested in buying a new gaming machine and my friend told me about Digital Storm.  I am very impressed about what iv seen//read.
One thing Im really scepticle about is the liquid cooling.
I never had a pc with it and not sure how to maintain it. Im asking for opinions on how its really that much better than fan coolin and stuff like that n if its all around worth it. <_<
Any info and opinions are welcomed plz
Im looking to spend around max 2200$$ on the machine.  Not sure if that helps the decision on air or liquid cooling.  Thanks again.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 09 May 2009 at 5:35am
with your budget go with air.
do have a config yet?
  Quote Teckno Quote  Post ReplyReply bullet Posted: 09 May 2009 at 5:43am
Not yet ><
  Quote Teckno Quote  Post ReplyReply bullet Posted: 09 May 2009 at 6:01am
279875 is my Ticket #
I think I forgot speakers, also not sure how well that harddrive is.
Let me know what you think and how I can improve my Ticket in anyway if your bored or dont mind ^^
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 09 May 2009 at 6:10am
well first off why are you wasting your money on ph II the i7 will perform much better and OC higher
second you need to go with a 64bit OS cause the 32bit can not use your total system ram and trust me that setup you have with 32 is not the same as with 64bit.
forget mcafee and go with eset smart security.
drop the backup power unless you really need it, if you do then get that and your mouse and etc from newegg and save money.
having said all of that, this system is much better and has more ram and will OC higher and have better CPU cooling, much better CPU cooling:
here you go Ticket# 279878 --- Price: $2189. (To see this build click here) Price after current promotion $2089.
System Memory: 6GB DDR3 1333MHz Mushkin (Highly Recommended) (Digital Storm Certified)
Card Reader: - No Thanks
Video Card: 1x NVIDIA GeForce GTX 275 896MB (Includes PhysX Technology)
Extreme Cooling: AIR: Stage 2: Noctua NH-U12P High Performance Cooler (Compatible With i7 Processors)
LCD Display: - No Thanks
better CPU, better CPU cooler, better PSU, better mobo, more ram better OS.
this has much more room for upgrade down the road also.
as for HDD the one you have now is good, wait till end of the year or H1 of next year and upgrade to SSD when the price is right
  Quote Teckno Quote  Post ReplyReply bullet Posted: 09 May 2009 at 6:22am
Thanks alot for the info.  Im gonna save that ticket.
Some of the new games I have is Left 4 Dead and Unreal Tournament 3.
So this ticket should make me a machine to run these games fairly well yeah?
I'm also big on the MMO Final Fantasy XI.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 09 May 2009 at 6:26am
what GPU you need depends on what resolution you are running, so what resolution are you going to be gaming at?
  Quote Teckno Quote  Post ReplyReply bullet Posted: 09 May 2009 at 6:33am
Honestly I dont know.  I run a 24"
Its the only good thing I have on my desk atm <_< Whatever works best with the setup im getting ill use.
Your prolly /sighing by now at how bad I am with this stuff.
I forget what res I was using and cant check atm cause I have something running.  I do know it was pretty high maybe 1200//1600 or something.  I know it runs the games like crap  lol ><  Pc im on atm I wont even mention it just plan sucks.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 09 May 2009 at 6:56am
so you are at 1900 x 1200 then you need dual sli 275 that puts you at $2388 after discount.
  Quote Teckno Quote  Post ReplyReply bullet Posted: 09 May 2009 at 7:01am
I can work with that, thanks.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 09 May 2009 at 7:03am
My pleasure good luck
  Quote Teckno Quote  Post ReplyReply bullet Posted: 09 May 2009 at 7:06am
Ok I added adjustments.
I always wanted a gaming pc with two video cards in it. ^^
Thanks again for all your help esp for taken your time to help a pc newbie.
Take care, see ya again around forums I hope!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 09 May 2009 at 7:12am
well final fantasy is listed as supporting sli or sli profile so you should be good to go good luck and see you around
Edited by DST4ME - 09 May 2009 at 7:12am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 09 May 2009 at 4:53pm
What he does on his pc is different then we do, the games he plays at high settings needs 2 gpus to be over 60fps.
Edited by DST4ME - 09 May 2009 at 5:00pm
