Always built my own in past
Post Date: 2013-05-21
WolfAK View Drop Down
  Quote WolfAK Quote  Post ReplyReply bullet Topic: Always built my own in past
    Posted: 21 May 2013 at 2:29pm
Like to stay under $3,000 (keep my amazing lovely wife happy!)
Have always built my computers in past. This go around want to have a high quality gaming machine built for me. I just want to open the box plug it in and play! I want to be blown away. I work hard now I want someone to do the hard work. I am a perfectionist though. Fast Fast Fast please.
Gaming with all the graphic goodness. Mostly MMO's with some FPS thrown in and single player RPG's. I also do some video encoding and burning to blu-ray as well as photo editing.
May want to try a three monitor setup. Would a 4GB card do anything for me for multi-monitor over a 2GB card?
Also want to keep everything cool but keep the computer as quite as possible.
Saved Ticket #: [829987]
Chassis Model: Special Deal Hot Seller - Corsair 650D
System Memory: 16GB DDR3 1866MHz Corsair Dominator DHX (High-Performance)
Hard Drive Set 1: Operating System: 1x (256GB Solid State (By: Samsung) (Model: 840 Pro Series)
Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital VelociRaptor (10K RPM) (64MB Cache)
Optical Drive 1: Blu-Ray & DVD Writer/Reader (Burn + Play Blu-Ray & DVDs) (12x BD-R)
Video Card: 1x NVIDIA GeForce GTX 680 2GB (Includes PhysX) (Overclocked EVGA)
Extreme Cooling: H20: Stage 2: Corsair H100i 240mm Radiator Liquid CPU Cooler (Extreme-Performance Edition)
Windows OS: Microsoft Windows 8 (64-Bit Edition)
Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Extra Large)
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 22 May 2013 at 3:47am
Hi WolfAK ..... Welcome to the forums.
Thats a real nice build but I would change a couple of selections to get the best bang for your dollar.
Change ram to DS standard.    The tall heat spreaders do look nice but not needed.
Go with WD Caviar Black HDD.   Excellant HDD.
Put the money saved into a sli, 2x gtx 670.   The gtx 670 is almost the same performance as 680 and the sli will almost double your performance, especially if you want the game on multi monitor or higher res 30" .
For about $130 extra, if I figured it right, and still under $3000 , you'll have a stronger setup.
4gb vram is little used.   Higher res multi monitor , apps with hd large files or heavily modded Skyrim with texture mods is about it.
lusiphur View Drop Down
  Quote lusiphur Quote  Post ReplyReply bullet Posted: 23 May 2013 at 6:54am
I'd change Windows 8 to Windows 7, but that's just me.
Marshmellow Fluff is proof of a higher existence.
Tardis >>> My Digital Storm Bolt with GTX TITAN
This page was generated in 0.1009521 seconds.
