Am I better off with with Air or liquid cooling?
Post Date: 2010-02-05
iraweiss View Drop Down
  Quote iraweiss Quote  Post ReplyReply bullet Topic: Am I better off with with Air or liquid cooling?
    Posted: 05 Feb 2010 at 1:47pm
Here are the configurations I started with:
Digital Storm Saved Config 380672 has Extreme Cooling: H20: Stage 2: Asetek Liquid CPU Cooler (120mm Radiator).
Digital Storm Saved Config 379418 has Extreme Cooling: AIR: Stage 1: Cooler Master V8 High Performance Cooler (Compatible With ONLY i7 Processors).
Digital Storm Saved Config 380937 has Extreme Cooling: AIR: Stage 1: Noctua Dual 120mm Fans High Performance Cooler (Compatible With ONLY i7 Processors)
Digital Storm Saved Config 380795 has Extreme Cooling: AIR: Stage 2: Noctua NH-D14 Extreme Performance Cooler (Compatible With ONLY i7 Processors)
Edited by iraweiss - 06 Feb 2010 at 7:03am
Ira S Weiss
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 05 Feb 2010 at 1:57pm
The Asetek is a joke, get the Noctua cooler. Noctua will be cooler, quieter, last longer, and help cool other parts of the motherboard. The only drawback to the Noctua is that in shipping it has a higher chance of shipping damage do to its weight. But DS has it pretty well packed, and has minimal issues.
Mekerek View Drop Down
  Quote Mekerek Quote  Post ReplyReply bullet Posted: 05 Feb 2010 at 2:39pm
What gives the Noctua advantage over the Cooler Master V8? Most have suggested the V8 in the past.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 05 Feb 2010 at 3:09pm
who is most? lol
Noctua is better quality, quieter, and cools better.
  Quote Mekerek Quote  Post ReplyReply bullet Posted: 05 Feb 2010 at 3:39pm
'most' is the web at large and review sites etc. While not scientific, I try to combine my impression from the various sources for products. V8 certainly gets more mention than Noctua but spec wise, the db's are about 3 less for Noctua so that's good enough for me :)
  Quote iraweiss Quote  Post ReplyReply bullet Posted: 05 Feb 2010 at 4:54pm
Do you have the Noctua model number so I can check it out on the Egg?
Ira S Weiss
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 05 Feb 2010 at 5:05pm
I believe it is the U12p... do not go off new eggs reviews. lol mostly clueless folk complaining about products that they have no idea how to install/run or how great a product is because they did get it to work. Smile
  Quote iraweiss Quote  Post ReplyReply bullet Posted: 05 Feb 2010 at 5:18pm
FWIW the Noctua U12P gets glowing Newegg reviews. I'll keep checking sources as with tonight's snow in Columbus I'm going nowhere. Keep the comments coming...
Edited by iraweiss - 05 Feb 2010 at 5:18pm
Ira S Weiss
  Quote Asangard Quote  Post ReplyReply bullet Posted: 05 Feb 2010 at 5:55pm
If you google the model # or manufacture and model # you usually can find profession reviews of products.
Here are 2 reviews I found:
I hope they help.
Edited by Asangard - 05 Feb 2010 at 6:05pm
Dragoonseal View Drop Down
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 05 Feb 2010 at 6:47pm
Alex just posted in General Discussions a bit ago that starting today Digital Storm now carries the Noctua D14! This is the bigger badder brother of the U12P. It cools veeery well even at low fan RPMs so you can get some whisper quite rock awesome air cooling.
But be aware it is very large, only certain motherboards are supported, and it may block your ability to put a RAM fan cooling on your RAM. Here is a compatibility list from Noctua for motherboards.
  Quote iraweiss Quote  Post ReplyReply bullet Posted: 06 Feb 2010 at 7:04am
Here's where I'm currently at but will step down to the Noctua U12P if there are installation issues with the memory fans.
Chassis Model: Cooler Master HAF 932 (Black OPS Edition)
Motherboard: ASUS P6X58D Premium SLI (Intel X58 Chipset) (Supports SLI or CrossFire)
System Memory: 12GB DDR3 1600MHz Corsair Dominator DHX (High-Performance)
Expansion Bay: Internal Digital Media Card Reader (Black)
Hard Drive Set 1: Operating System: 1x (2TB Western Digital (7200 RPM) (64MB Cache) (SATA) (Extreme Speed WD2001FASS 2TB)
Optical Drive 1: Blu-Ray Writer/Reader (Burn Blu-Ray discs and play them)
Optical Drive 2: DVD±R/RW/CD-R/RW (DVD Writer 22x / CD-Writer 48x) (LightScribe Edition)
Video Card: 1x ATI Radeon HD 5770 1GB
Noise Reduction: Noise Suppression Package (Optimized Airflow & Fan Speeds with Noise Dampening Material)
Boost Memory: Yes, Overclock memory frequency (Includes Memory Fan Kit Installed)
Keyboard: Microsoft Multimedia Desktop 3.0 (Multimedia Keyboard + Optical Wheel Mouse)
Do you have any other configuration suggestions?
Ira S Weiss
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Feb 2010 at 12:14pm
@iraweiss some of us here are much more experience then the bs responses you read on the web, me and justin are here to clear up exactly that kind of bs.
if me or justin tell you that asetek is bad, don't ask anymore questions, just run, run its a bad gf man
ok no really run but ask as many questions as you like but don't respond back with what you heard on the web, forget that crap.
I would not own an asetek if you bought it and installed it for me at no charge.
I would own a Noctua in a hart beat.
now tell me what resolution you gonna be gaming at and what your budget is and lets fixup that crazyness you call a config, I call that waste of your money.
so lets get you a powerful beast where every dime goes to power and not waste.
This page was generated in 0.1130371 seconds.
