Am Pricing Out a Dreadnought System ...
Post Date: 2012-01-23
Raptor22ADF View Drop Down
  Quote Raptor22ADF Quote  Post ReplyReply bullet Topic: Am Pricing Out a Dreadnought System ...
    Posted: 23 Jan 2012 at 3:02pm
$2500-$3000
Faster w/Better Graphics than a high-end Toshiba laptop (that I currently have - Qosmio X770)
Silent Hunter 4, Sims 3, Ghost Recon series, Bioshock Infinite (not out yet), flight simulation - plus the overnight crunching of prime numbers via PrimeGrid. Also a few graphics programs like Poser Pro 2012, Photoshop Extended, and Cinema 4d Prime.
Saved Ticket #: 647249
* Intel Core i7 2600K 3.40GHz (Unlocked CPU for Extreme Overclocking) (Quad Core)
* ASUS P8Z68-M PRO (Intel Z68 Chipset) (Features Intel Quick Sync Technology)
* 16GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested)
* 800W Corsair GS (Dual SLI Compatible)
* 2x (750GB Seagate Barracuda (7200 RPM) (32MB Cache) (Model: HD-ST3750528AS) - nonRAID
* DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x)
* Wireless PCI 802.11n Up to 300Mbps (Supports 802.11n/g/b) (Model: 3FMPCIMWN-R)
* 1x NVIDIA GeForce GTX 590 3GB (Includes PhysX Technology)
* Integrated Motherboard Audio
* AIR: Stage 2: Corsair A70 Dual 120mm Fans High Performance Cooler
* Upgrade Chassis With LED Performance Fans (Red) (Up to 6 Fans)
* Noise Suppression Package Stage 2 (Optimized Airflow & Fan Speeds with Noise Dampening Material)
* Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires Pro or Deluxe Series Motherboard)
* Microsoft Windows 7 Professional (64-Bit Edition)
* Advanced Recovery Kit (40GB Hard Drive Partition of Image With OS & Drivers)
* Life-time Expert Customer Care with 3 Year Limited Warranty
Two questions:
a) Is the power sufficient to handle the config?
b) Would the overclock generate enough heat to warrant liquid cooling?
I love the look of the Dreadnought case. Has that "I'm not here to do Powerpoint" image quality to it.
Edited by Raptor22ADF - 23 Jan 2012 at 3:16pm
LaneHayes View Drop Down
  Quote LaneHayes Quote  Post ReplyReply bullet Posted: 23 Jan 2012 at 4:07pm
The pros will come in here in a second and fix this rig, but seriously, do noooot do the 590. My friends has died once, and my BF3 looks better than his and doesnt catch on pretty much identical systems (2x 570s here). Also, SWTOR has been unplayable for him since launch basically.
I have a Noctua DH air cooler, and my CPU never gets above 55 C, so you definitely don't need closed circuit liquid cooling. A h80 or 100 would look better inside but blocks some of the airflow. If you're just doing a single video card setup, feel free to use one of these instead as it won't really make a cooling difference.
The design of the HAF-X is such that i can't really see a noise suppression package doing much, its incredibly open. Its also very quiet anyway.
  Quote Raptor22ADF Quote  Post ReplyReply bullet Posted: 23 Jan 2012 at 4:18pm
So…
Substitute the NVIDIA GeForce GTX 580 3GB Classified Ultra (PhysX) (EVGA 03G-P3-1595-BR) for the 590?
I like lots of capability that I wouldn't have to upgrade anytime soon.
Edited by Raptor22ADF - 23 Jan 2012 at 4:21pm
  Quote Raptor22ADF Quote  Post ReplyReply bullet Posted: 23 Jan 2012 at 5:12pm
BTW, my monitor is an HP-2310m which up to now has been used with an old Mac-Mini.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 24 Jan 2012 at 1:34pm
A70 and noctua are king in performance till you get to stage 4 lc.
h80/h100 are not real lc systems as in they don't give you lc perfomrance, at best they match the noctua d14 temps, I would recommend to never go with those self contained coolers.
with the a70 or d14 oc temps are no issue.
I see your monitor has a res of 1920 x 1080, for that res the 580 classified is a waste of money, actually for any res the 580/classified is a waste of money.
if you want to max out your res in games you need/want sli 570 which will beat the 590 and eat the 580 classified for snack.
your config is not your money well spent and has contradictions, for example the led fan upgrade is loud and then you adding noise package, those two work against each other, and make no sense, you dont need fan upgrade, and noise package just slows down your fans and takes away from airflow, and at best gets rid of 10% noise which is nothing, if you want led fans on haf let me know, it needs to be done in a different way so that you get led fans but no extra noise.
also most of your noise is gonna come from gpu's fans when under load and the only way to get rid of that is to put them under lc.
your config is around $2800, for $19 you can have this config that will eat your config for snack and it has better performing more reliable parts:
Here you go Ticket# 647566 --- $2,819 (To see this build click here)
haf 200mm non led fan
Ask for vcore lower then 1.4 for your oc.
Edited by DST4ME - 24 Jan 2012 at 9:08pm
  Quote Raptor22ADF Quote  Post ReplyReply bullet Posted: 24 Jan 2012 at 5:50pm
Absolutely... WOW!
Many many thanks DST4ME !!! I'll be back in a bit ...
Edited by Raptor22ADF - 24 Jan 2012 at 5:53pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 24 Jan 2012 at 9:10pm
My pleasure
if you play games like batman or other games that need more vram just change the sli 570 in my config to sli 570 2.5GB version, it will add another $100 to the price.
  Quote Raptor22ADF Quote  Post ReplyReply bullet Posted: 24 Jan 2012 at 9:57pm
I changed the config a bit: Ticket #647736
Does anyone make a higher-res 23" monitor that also has a non-glare screen?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 24 Jan 2012 at 11:26pm
You raised the cost of the system and lowered its performance, not good.
for recovery, if your hdd goes bad then your recovery is gone, which is why I gave you the win7 cd instead.
as for monitors we all like and use IPS panels from dell, many of us have them, we range from u2410, u2411, u2412, u2311, u2312, to u30.
Dell UltraSharp U2410
Dell UltraSharp U2412M
Dell UltraSharp u2312
Dell UltraSharp U3011 30"
  Quote Raptor22ADF Quote  Post ReplyReply bullet Posted: 24 Jan 2012 at 11:50pm
I currently have two Toshibas that put the recovery on a partition, so it was what I am used to. I can see your point, though, about having the CD instead. Will flip back to that.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 24 Jan 2012 at 11:56pm
Keeping it simple is the key, with the cd you can do all kinds of stuff in the worst case scenario.
  Quote Raptor22ADF Quote  Post ReplyReply bullet Posted: 25 Jan 2012 at 3:37am
I clicked on a slightly different config, the one that starts at $3000. I changed the drives and the OS, but otherwise kept everything the same:
Ticket #: 647799
Though I said $3000 was my budget, I can actually push that to $3500 if necessary.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Jan 2012 at 11:08pm
thats not good at all, go back and read what I said about the cpu coolers, gpus and etc, you need to change the mobo/psu/cpu cooler/gpu/hdd in your config# 647799
  Quote Raptor22ADF Quote  Post ReplyReply bullet Posted: 26 Jan 2012 at 12:04am
Different config - 648184
Why is the 580 a waste of money? Details, please.
Found this nice review @ Overclockers Club. Their only complaint is the price.
I intend on upgrading my monitor soonest.
Edited by Raptor22ADF - 26 Jan 2012 at 1:54am
  Quote FrankW Quote  Post ReplyReply bullet Posted: 26 Jan 2012 at 8:45am
Hi Rapter,
You are all over the place picking the wrong equipment and making poor choices. Every time you do another profile you solve some problems but create others. For a 1920 x 1080/1200 monitor resolution DST4ME recommendation is the system you want. It has all the power you need with the best power supply and GPU you can buy for the money. If you think you need more GPU power for non-gaming then get the 570 2.5Gb.
Do your self a favor and take another look at DST4ME"s system. Any changes you make to that system is a mistake except for the 2.5Gb GPUs. Now if you just want to spend more money for the same performance then that is your choice and have at it.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 26 Jan 2012 at 9:09am
Hi Raptor......  Your quote   " Found this nice review @ Overclockers Club. Their only complaint is the price."
What the guys are saying is that the price IS the problem.  There's nothing wrong with the 580, in fact most that have them will praise the performance.  BUT, for the extra $150 you're getting only marginal if any performance increase over the 570.
The people that praise the 580 would also praise the 570 for the same reason and have extra $$$ in their pocket.
If you want the 580, then it's your $$$ and your ultimate decision.  Sometimes a personal preference does come into play.  Here, best bang for the buck rules.Big%20Smile
DST's build is tops.
Good Luck Big%20SmileBig%20Smile
Edited by bprat22 - 26 Jan 2012 at 9:10am
  Quote Raptor22ADF Quote  Post ReplyReply bullet Posted: 26 Jan 2012 at 12:34pm
Question: why do some of the motherboard options say "without SATA 3g issue"? Is that just a simple way of saying it doesn't support 3g SATA or that something is wrong with 3g SATA?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 26 Jan 2012 at 12:47pm
Earlier ASUS p67 mobo, early 2011, had SATA 3 problem.  Been fixed with B3 revision.
  Quote Raptor22ADF Quote  Post ReplyReply bullet Posted: 26 Jan 2012 at 4:16pm
Okay.
I went back to DST's config and only added RAM, wireless LAN, Win7 Pro, and tweaking the OS.
#: 648319
  Quote FrankW Quote  Post ReplyReply bullet Posted: 26 Jan 2012 at 4:36pm
Hi Raptor,
Good for you, that will be a super system. I do suggest you pass on the OS tweak. What they do is disable, turn off or delete software that they think you won't use. The problem is they don't know what you might want to use. They could disable something you need or just want to use and it won't be there. For me it is a lot better to get your system, set it up like you want and then clean up what is not needed.
Don't forget to order your free T-Shirt and adding the fan to the top of the case. Nice system.
Edited by FrankW - 26 Jan 2012 at 4:39pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 26 Jan 2012 at 4:46pm
Raptor....Awesome rig.           Don't forget your free t-shirt. It is free       Good Luck.          Oops...Frank beat me to the t-shirt.
Edited by bprat22 - 26 Jan 2012 at 4:49pm
  Quote Raptor22ADF Quote  Post ReplyReply bullet Posted: 26 Jan 2012 at 4:52pm
Okay... no OS tweak. Gotcha.
Does this fan that is recommended replace some other fan, or is it to insure better airflow?
BTW, what keyboards and mice are you all using?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 26 Jan 2012 at 4:59pm
The fan adds another fan, total of 2, to the top for best airflow.   The keyboard and mouse I use are cheapo Dell's so can't go by me. I need to upgrade the mouse. I'm getting killed in BF3
  Quote Raptor22ADF Quote  Post ReplyReply bullet Posted: 26 Jan 2012 at 5:02pm
I always have MS mice on my systems -- even on a Mac. Did you know their Intellimouse Explorer, once marketed for business, is passed off as a gaming mouse?
http://www.microsoft.com/hardware/en-us/p/intellimouse-explorer-3.0
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 26 Jan 2012 at 5:04pm
  Quote Raptor22ADF Quote  Post ReplyReply bullet Posted: 28 Jan 2012 at 7:21pm
Just noticed this = Antec DF-85 case
If I substituted this for the Cooler Master 942 HAF X, would anything change in the cooling config?
  Quote Raptor22ADF Quote  Post ReplyReply bullet Posted: 28 Jan 2012 at 8:21pm
A bit different config in a different case:
#649185
I have a 560m in a Toshiba laptop right now and it handles things pretty well (the CPU, alas, is only a 2ghz quad).
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 28 Jan 2012 at 10:09pm
laptop is a whole different ball game, you can't look at that and get any info whatsoever for a desktop.
congratulation, you just cramped yourself and parts with lack of room and lost lot of airflow comparing to the haf x.
No but seriously go back to haf x, its not even comparable to that case, its a no brainer.
I don't understand a few things, why you keep changing the ssd to a hdd for hdd1?
change sli 560 back to 570, it will not have the same performance, and it may come up short in vram for some games.
  Quote Raptor22ADF Quote  Post ReplyReply bullet Posted: 29 Jan 2012 at 12:24am
Jus' lookin'
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 29 Jan 2012 at 2:30pm
lol So why you keep changing the ssd to hdd?
  Quote Raptor22ADF Quote  Post ReplyReply bullet Posted: 29 Jan 2012 at 7:31pm
I have an SSD in my MacAir, and I'm used that. But with a big desktop, I just kinda sorta felt a couple of big drives are the way to go.
When I order this thing, the SSD will be back in there.
Old Fogey, I guess.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 29 Jan 2012 at 11:25pm
OH ok so you gonna add the ssd yourself, very well then.
