Another nub needs help :D
Post Date: 2012-05-21
v12golfcart View Drop Down
  Quote v12golfcart Quote  Post ReplyReply bullet Topic: Another nub needs help :D
    Posted: 21 May 2012 at 11:28pm
Budget: I'm trying to stay under $4k if possible, but over by a couple $100 should be fine.
I've been gaming for a long time, and I like having the highest settings, but tired of overheating comps / having to upgrade. I want a great gaming PC, will use a 24" 1920x1080, and occasionally will have dual monitors (for work). Would like this computer (esp, the graphics card) to last for a few years over several game generations, so I don't mind spending now. I don't have access to direct ethernet connection, so I do need wireless capabilities. I do also want it to look awesome. Last thing, I set to stage 1 overclock to be conservative, but happy to do stage 2 if the extra burden isn't that much).
My big problem is I am prone to overkill when I build my comps :-p, so happy to scale stuff back if you think it's unnecessary - I def don't want to waste money.
Games on (hopefully) highest video settings. These days its GW2, D3, SC2, WC3. Also into music editing which runs some heavy software.
Ticket Number: 691125
Total Price with Instant Savings: $4,042.00
Motherboard: ASUS P9X79 DELUXE (Intel X79 Chipset) (Features USB 3.0 and SATA 6Gb/s)
Hard Drive Set 1: Operating System: 1x (2TB Hitachi/Seagate (7200 RPM) (32MB Cache)
Internet Access: Wireless PCI-E 802.11n Up to 300Mbps (Supports 802.11n/g/b) (Model: ASUS PCE-N15)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 680 2GB (Includes PhysX)
Chassis Airflow: Upgrade Chassis With LED Performance Fans (Blue) (Up to 6 Fans)
LaserMark: Digital Storm LaserMark Service - Graphic (Non-Window Metal Side Panel)
Display: - No Thanks <b></b>
Keyboard: - No Thanks <b></b>
Mouse: - No Thanks <b></b>
Orange7 View Drop Down
  Quote Orange7 Quote  Post ReplyReply bullet Posted: 22 May 2012 at 3:36am
All in all, an awesome desktop. However, may I recommend replacing the first hard drive with an SSD, and then possibly increasing the using the multimedia/data hard drive if you need more space? You will notice a huge difference between performance in boot time, load time, etc. with a solid state drive over any HDD.
DS xm15 Stage 4
i7-3820 (2.7GHz/3.7GHz)
16GB 1600MHz DDR3
GT 630, 1GB
240GB Intel 520
  Quote Orange7 Quote  Post ReplyReply bullet Posted: 22 May 2012 at 3:37am
Sorry. This is what that meant to say.
All in all, an awesome desktop. However, may I recommend replacing the first hard drive with an SSD, and then possibly increasing the multimedia/data hard drive capacity if you need more space? You will notice a huge difference between performance in boot time, load time, etc. with a solid state drive over any HDD.
DS xm15 Stage 4
16GB 1600MHz DDR3
GT 630, 1GB
240GB Intel 520
  Quote v12golfcart Quote  Post ReplyReply bullet Posted: 22 May 2012 at 7:44am
Thanks orange - you're right, I'll prob switch first HD to the Corsair 120GB SSD.
Still open to other comments on optimizing this, and one more question. I'm no cooling expert, so I just wanted to double check - is the cooling system selected enough to handle these settings, especially given the x2 graphics cards and the stage 1 overclock?
Thanks so much for the help everyone! I'll finalize purchase around end of week.
Edited by v12golfcart - 22 May 2012 at 7:54am
  Quote FrankW Quote  Post ReplyReply bullet Posted: 22 May 2012 at 8:07am
Hi v12golfcart,
That is a pretty good build with a few of exceptions.
1. With the Deluxe Mobo you get WiFI and Blue Tooth so you can drop the Wireless card.
2. Change the PS to the Corsair 1050. You get a better power supply with a longer factory warranty.
3. A SSD would be a much better choice for the 1st drive. If you don't want or don't have the budget for the SSD then put the 1TB WD HDD as the 1st drive. It has better performance than the drive you have in 1st now. My choice by a long shot is the 180Gb Intel 520 SSD.
4. You have picked a great case with big, slow moving, fans that move a bunch of air. The fan up grade will replace 200mm fans with 120mm fans. Not a good idea. The front fan is a 230mm fan with red LEDs. Highly recommend you drop the fan upgrade.
5. With the 240mm cooler you should move up to the stage 2 OC.
6. You might want to get Win-7 Pro rather than the Home edition. You won't be able to add any more memory with the Home edition. It is limited to 16Gb of ram.
According to what kind of work you do you may not need to get the 3930K. As far as gaming is concerned the 3770K CPU is all you need. That will save you $300 on just the CPU.
Edited by FrankW - 22 May 2012 at 9:16am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 22 May 2012 at 8:12am
Hi Frank....I think the H100 is gone from the configurator and replaced with the Vortex 240mm unit.
They keep changing things on us.Oops
  Quote FrankW Quote  Post ReplyReply bullet Posted: 22 May 2012 at 9:15am
Thanks bprat22. You know I saw the 240mm rad and was wondering about that. To lazy to check the configurator.
  Quote Asangard Quote  Post ReplyReply bullet Posted: 22 May 2012 at 9:42am
DS had the same company that makes the Corsair H-100 make Vortex 240mm. Essentially it is the H-100 with the DS logo on it.
  Quote v12golfcart Quote  Post ReplyReply bullet Posted: 22 May 2012 at 2:54pm
Awesome - thanks so much for the help everyone! I had heard customer support for DS was great, but I didn't realize it also had such a helpful community as well, definitely appreciate it.
All the comments make perfect sense, here's the latest build. If y'all think it makes sense, I'll probably pull the trigger in the next day or two (if I can wait that long haha).
Ticket Number: 691280
Total Price with Instant Savings: $3,861.00
Edited by v12golfcart - 22 May 2012 at 2:55pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 22 May 2012 at 3:02pm
That is a great build.       Just one small mistake......add-in your free t-shirt.       Go for it and keep us updated.      Best of luck.
