Antec 900 inside LED color?
Post Date: 2008-08-18
NoobieHowzerMD View Drop Down
  Quote NoobieHowzerMD Quote  Post ReplyReply bullet Topic: Antec 900 inside LED color?
    Posted: 18 Aug 2008 at 2:07pm
So the front fans of the case come stock with blue LED's.  Would the blue internal lighting look the best?  Or would the Red LED's from DS with the stock blue fan lights look cool?  Anyone have any combination of color or should I just go with all blue?
  Quote Alex Quote  Post ReplyReply bullet Posted: 18 Aug 2008 at 2:39pm
As a heads up, in the "Customer Reviews" section there are some systems that have that combination. You might want to check that out and see if that works for your taste.
Regards,
Alex
  Quote NoobieHowzerMD Quote  Post ReplyReply bullet Posted: 18 Aug 2008 at 6:40pm
Hmm couldn't find any 900's on the customer reviews.  I checked youtube though, and saw a video with green and blue LED's, and it looked pretty cool.  So I think I might go with the Red and Blue.
SunfighterLC View Drop Down
  Quote SunfighterLC Quote  Post ReplyReply bullet Posted: 18 Aug 2008 at 8:15pm
Red and blue looks kinda silly...i should know...the bottom of my Cosmos S case is red, the top blue.
I guess if you like superman its alright...
E8500@ 4.03Ghz
XFX 790i Ultra
1000W Corsair HX
2 280 GTX EVGA FTW
4GB OCZ Reaper 1800Mhz
250-80-300GB VR HD
Logitech Z-2300 2.1 Speakers
Asus Xonar 7.1
Costone View Drop Down
  Quote Costone Quote  Post ReplyReply bullet Posted: 18 Aug 2008 at 9:04pm
....or The Giants..
  Quote NoobieHowzerMD Quote  Post ReplyReply bullet Posted: 18 Aug 2008 at 9:13pm
So I should just stick to normal and go with all blue?
widdlecat View Drop Down
  Quote widdlecat Quote  Post ReplyReply bullet Posted: 19 Aug 2008 at 12:39am
d00d! Your CosmosS is what is silly! Don't blame your colors... Wink
Actually, color combos can have a stunning effect. It's all a matter of personal taste. I say go with what you like! It's your rig! Thumbs%20Up
Tyler Lowe View Drop Down
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 19 Aug 2008 at 1:23am
Blue and green look very good together IMO. I installed some green UV reactive SATA cables in my system with a blue cathode and the effect is very pleasing, at least to my eye. You really cannot go wrong with a monochromatic scheme, it will always look at least acceptable, but I also think if it's done well, having multiple colors is more interesting to look at. On the other, other hand, you'tre not going to look at the lighting much once you see what your new DSO system does with games.Wink
Edited by Tyler Lowe - 19 Aug 2008 at 1:23am
  Quote NoobieHowzerMD Quote  Post ReplyReply bullet Posted: 19 Aug 2008 at 6:18am
Ha, good point Tyler.
  Quote widdlecat Quote  Post ReplyReply bullet Posted: 19 Aug 2008 at 2:22pm
Do they make cold cathode tubes in pink??? or UV (blacklight)! That would be kewl! Big%20smile
