Asetek LCLC 120mm cpu fan?
Post Date: 2012-07-26
volkman5150 View Drop Down
  Quote volkman5150 Quote  Post ReplyReply bullet Topic: Asetek LCLC 120mm cpu fan?
    Posted: 26 Jul 2012 at 6:13pm
Hi guys,
I had to RMA my DS pc, and since they're gonna be having the pc at their facility next week I was thinking about upgrading the cpu fan in order to have a quieter pc (it's the Marauder level 1). I was looking at the asetek lclc 120 mm fan that DS sells, does anyone know if this thing is really quiet? Anyone tried overclocking with it? I found the standard cpu fan to be way too noisy, so I would like something that makes minimal noise.
On a side note, the mobo is crossfire compatible. Even though DS doesn't advertise selling the radeon hd 7750 gfx card on their online store, if I wanted to would I be able to purchase one from them and have them upgrade to crossfire?
Thanks!
RJEwing View Drop Down
  Quote RJEwing Quote  Post ReplyReply bullet Posted: 26 Jul 2012 at 7:46pm
I don't think DS would have a problem doing the work, they are very helpful! I would give them a call to double check but I doubt it would be an issue. As for the fan, I've never used the lclc, so I can't help you out.
