ASUS Rampage IV Extreme and NH-D14
Post Date: 2013-10-20
Jagblade View Drop Down
  Quote Jagblade Quote  Post ReplyReply bullet Topic: ASUS Rampage IV Extreme and NH-D14
    Posted: 20 Oct 2013 at 6:32pm
I've tried to post this three times and it keeps refusing because of a picture, so I'll keep it short and sweet. Oops I'm planning to order a build before next summer.
Configuration involves:
Case: HAF X
Motherboard: ASUS Rampage IV Extreme
Cooler: Noctua NH-D14
RAM: 16GB (4 sticks) Corsair Dominator Platinum DHX
The DIMMS on this board are set up as follows:
llll # llll
l = DIMM / # = Processor
I would need two RAM sticks on either side to set them up in Quad Channel and I know the NH-D14 is a pretty massive cooler. Would it all fit correctly or should I go for a Corsair H80 instead?
sbradfor View Drop Down
  Quote sbradfor Quote  Post ReplyReply bullet Posted: 20 Oct 2013 at 8:19pm
I was told by a Digital Storm rep that if I wanted to use the Noctua, I should by the DS memory only because it will fit under the cooler.
  Quote fstcvc Quote  Post ReplyReply bullet Posted: 20 Oct 2013 at 8:43pm
Like already said, you have to have low profile memory modules to fit under the Noctura. Pretty much every motherboard will have the same issue as the memory is usually in close proximity to the CPU to keep the distance of the connection short. The Noctura and H100i have about the same cooling capabilities so the the H80 probably won't keep the CPU as cool as either of those options... I would opt for the DS memory and the Noctura.
  Quote retirednavysnipe Quote  Post ReplyReply bullet Posted: 21 Oct 2013 at 6:33am
Just glancing at my Asus Rampage IV extreme, if I wasn't running liquid cooling there would be no way to squeeze a big cooler on the Cpu. I use the Adata ram the DS put in and it runs perfect.
Hailstorm Black Ops
I7 3930K 4.5GHZ
16GB 1600MHZ ram
2 x GTX 680
120 GB SSD, 1 TB hardrive
danjw1 View Drop Down
  Quote danjw1 Quote  Post ReplyReply bullet Posted: 21 Oct 2013 at 10:49am
Just a thought, Haswell-E, the replacement for the current Ivy Bridge-E should be out around then. It is slated for mid to late 2014.
This page was generated in 0.1162109 seconds.
