Asus Suite shows Chassis fans in red
Post Date: 2013-02-28
CmmdrShepard View Drop Down
  Quote CmmdrShepard Quote  Post ReplyReply bullet Topic: Asus Suite shows Chassis fans in red
    Posted: 28 Feb 2013 at 5:28pm
My Asus AI suite is showing all of my HAF X chassis fans in red with the speed of them ranging from 265 pm to 424 rpm; should I be concerned about these fans showing up in red.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 01 Mar 2013 at 12:03am
I don't believe your haf fans are connected to the mobo. then again I could be wrong, did you get upgraded fans?
  Quote CmmdrShepard Quote  Post ReplyReply bullet Posted: 01 Mar 2013 at 4:03am
I just got the standard chassis fans; after I posted this on the forum, in Asus Fan Xpert 2, I noticed that I was running in SIlent mode, which lowered the speed of the fans and caused them to show up in red since they were below the 600 rpm threshold.
By switching my mode to Full Speed, it increased the rpm of the case fans above 600 rpm threshold and all of my case fans have no warnings against them.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 01 Mar 2013 at 7:37am
Thanks for the feedback.  Good info. Strong
How'd you make out with the HafX Sata HotSwap issue in the other post?   Curious minds need to know. Big%20Smile
  Quote CmmdrShepard Quote  Post ReplyReply bullet Posted: 01 Mar 2013 at 7:46am
I enabled Hot Plug in the Bios for all SATA ports that were unoccupied.
The top hot swap drive I couldn't get the system to recognize the HDD in this drive but the bottom swap drive was recognized by the system after a few tries of getting the bay to snap into place.
The HDD I tested was on old HDD so now I know that the bottom bay can detect a HDD, I can purchase a new HDD and insert it into the bottom hot bay.
Getting a hot swap bay with a HDD screwed down to fit into its slot is finicky; it has to be in the right spot to get the back SATA connector to slot into the HDD SATA port.
Edited by CmmdrShepard - 01 Mar 2013 at 7:51am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 01 Mar 2013 at 7:58am
Nice.  Thanks .
Yep, others have complained of how finnicky they can be.
The bottom works but not the top?  Are there two sata cables coming off the back of the sled's backplane?  Maybe you just didn't want to fight with it anymore.
Have Fun. Big%20Smile
  Quote CmmdrShepard Quote  Post ReplyReply bullet Posted: 01 Mar 2013 at 8:02am
Haven't really looked inside for 2 SATA cables coming off the back of the sled's backplane.
This page was generated in 0.1191406 seconds.
