ASUS VH236H Monitor Problem!
Post Date: 2012-05-28
Surdect View Drop Down
  Quote Surdect Quote  Post ReplyReply bullet Topic: ASUS VH236H Monitor Problem!
    Posted: 28 May 2012 at 7:33pm
I got the ASUS VH236H and when i hooked it up to my ps3 with an HDMI cable, the sound from games doesn't work. All i hear is a loud buzzing noise coming from the back. When i plug in external speakers, the buzzing noise transfers to them. When i use my wireless ps3 headphones, then i can hear my game properly and no buzzing. I also tried netflix on my ps3 and no buzzing noise. Only when i play games the noise starts. Can anyone help? I hope i can fix it >.<
MICHAEL2A View Drop Down
  Quote MICHAEL2A Quote  Post ReplyReply bullet Posted: 28 May 2012 at 8:55pm
Are you using onboard audio from the mobo or a sound card?
NZXT Switch 810
Asus Rampage V ED10
16GB Corsair Platinum 3000mhz
i-7 X5960, 3.0Ghz-3.5Ghz
Intel 750 800GB NVME-SSD
Corsair H115i CPU Cooler
2 Asus Strix 1080 8GB SLI
Corsair AXi 1200 PSU
  Quote Surdect Quote  Post ReplyReply bullet Posted: 29 May 2012 at 1:43pm
well the ODE lvl 2, now called lvl 1, comes with an Integrated Motherboard Audio, but thats on the pc. when i hook up the ps3 to my monitor through hdmi cable, netflix works fine but for games, all i hear is a loud buzzing noise.
  Quote Alex Quote  Post ReplyReply bullet Posted: 29 May 2012 at 2:06pm
Basically you're having an audio issue with the PS3, and works fine with the computer?
It has to be a audio setting in the PS3 console, I would recommend messing with that to see if that resolves the issue?
  Quote Surdect Quote  Post ReplyReply bullet Posted: 29 May 2012 at 3:00pm
i haven't tried anything yet on the pc (no games) but maybe it is the ps3 thats giving the problems, ill mess with it today
