ATI HD 5870 + LG LED W2486L
Post Date: 2010-02-15
Ambidex View Drop Down
  Quote Ambidex Quote  Post ReplyReply bullet Topic: ATI HD 5870 + LG LED W2486L
    Posted: 15 Feb 2010 at 5:21am
Hi
Just got all my parts now.
But I was wondering about the type of cable I should use to connect the ATI HD 5870 with the LG LED 24" W2486L.
The LG LED Monitor has 2 HDMI inputs,
And the HD 5870 has 2 HDMI outputs.
Should I connect them with HDMI cable? Or doesnt it make any difference?
I have seen someone sort of couple the two outputs on their GPU's into 1 cable, an adapter or something, I am not sure. But anyways, should I do that?
Please show me how to get max out of my 2 lovely parts :)
Chris
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Feb 2010 at 5:32am
just one connection is all you need, the monitor might have many inputs to support different sources, and the gpu has different outputs to support different monitors.
in this case you go one gpu and one monitor, so you need one cable to connect the gpu to the monitor using one gpu output and one monitor input.
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 15 Feb 2010 at 5:26pm
HDMI cable or the regular GPU cable?
What is the best?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Feb 2010 at 5:45pm
not sure what you mean by regular gpu cable, are you refering to vga or dvi?
hdmi has dvi quality and sound, dvi has no sound, vga gives you the least quality of the 3.
  Quote Ambidex Quote  Post ReplyReply bullet Posted: 16 Feb 2010 at 4:44am
Thanks
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Feb 2010 at 5:13am
My pleasure
