ATI Radeon 6990 Crossfire cooling Question.
Post Date: 2011-06-14
RadioactiveRabbit View Drop Down
  Quote RadioactiveRabbit Quote  Post ReplyReply bullet Topic: ATI Radeon 6990 Crossfire cooling Question.
    Posted: 14 Jun 2011 at 5:18pm
If this is in the wrong topic Im sorry.
With two ATI Radeon 6990s will I have to go with Quad sub zero cooling or Dual subzero.
The reason im asking this is because their both dual gpu and i dont really know anything about cooling for computers.
Thank You for the help Big%20Smile
Sorry if this sounds like a dumb question as well.
  Quote Alex Quote  Post ReplyReply bullet Posted: 14 Jun 2011 at 5:38pm
No worries.
With two 6990's you will need to order our Quad version, as the water blocks for Dual GPUs are more expensive, which is why that package is slightly more thant he Dual version.
No question is dumb. Feel free to ask anything else.
  Quote RadioactiveRabbit Quote  Post ReplyReply bullet Posted: 14 Jun 2011 at 6:22pm
Thank you very much I appreciate the quick answer. Big%20Smile
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Jun 2011 at 6:38pm
RadioactiveRabbit we don't recommend dual gpu cards here liek the 590/6990,
they get beat by sli 570/580/6970, they run hotter then 2 cards in sli, they have less performance then 2 cards in sli, they can't be oced as much, and then tend to fail much sooner, also remmeber that tri sli/cf 570/580/6970 will beat quad sli/cf 590/6990.
also you dont' want to go quad sli/cf on the p67 mobo they can't truly support it as they don't have enough lanes.
also your res is the most important thing, at 1900 x 1200 you won't be able to tell the difference between sli/cf 570/6970 and tri sli/cf 570/580/6970 and quad sli/cf 590/6990.
  Quote RadioactiveRabbit Quote  Post ReplyReply bullet Posted: 14 Jun 2011 at 7:49pm
Yeah Thank you I was just reading up on that thinking that i might just go dual 580 or 6970 which do you recommend more?
  Quote Alex Quote  Post ReplyReply bullet Posted: 14 Jun 2011 at 8:45pm
From our experience, we recommend going with a Dual GTX 580 configuration.
  Quote RadioactiveRabbit Quote  Post ReplyReply bullet Posted: 14 Jun 2011 at 9:47pm
Thank you very much for your help! Big%20Smile
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Jun 2011 at 1:32am
Actually which you should go with all depends on your res, what res are you gaming at? if you are at 1900 x 1200/1050, you won't be able to tell the difference between sli 570/580 and cf 6970, sine sli 570 cost less, we recommend the sli 570.
If your res is higher then 1900 x 1200 then let us know that changes the game.
if your res is lower then 1900 x 1200 sli 570 is a waste and more power then you will need/notice.
sli 580 is great when its difference can be noticed, otherwise its money down the drain.
Edited by DST4ME - 15 Jun 2011 at 1:32am
  Quote RadioactiveRabbit Quote  Post ReplyReply bullet Posted: 15 Jun 2011 at 3:36pm
Sorry for the late reply.
My screen res is 2560x1600.
I am also looking for future proof cards.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Jun 2011 at 6:35pm
Ok future proof is not real, how future proof are quad sli 295 right now? not much at all, they can't do dx11 and get beat by sli 570.
to truly future proof you need to go with what you need now and then in the future upgrade to future cards so that you can meet future requierments, today's gpus can't meet tomorrow's requierments if you will.
For that res, for low aa settings we recommend sli 570 will ability to add a third, just in case you need it down the road.
for high aa settings we recommend cf 6970 with ability to add a third if needed.
tri cf 6970 beats cf 6990,
tri sli 570/580 beat sli 590.
there is no reason in the world to go with 6990 or 590.
so my advise is to go with cf 6970 or sli 570 depending on your aa settings, and in a couple of years upgrade gpus of needed.
Edited by DST4ME - 15 Jun 2011 at 6:36pm
  Quote RadioactiveRabbit Quote  Post ReplyReply bullet Posted: 16 Jun 2011 at 10:11am
I meant like to get a graphics card that wouldnt outdate as easily as other ones.
Unfournatly i can only afford to get two atm tho :( so would you recommened getting 2 way sli 580 3GB or 570?
  Quote RadioactiveRabbit Quote  Post ReplyReply bullet Posted: 16 Jun 2011 at 1:11pm
Also how often does DS do their sails on desktop computers and will they have one in october?
  Quote RiceEatin2000GT Quote  Post ReplyReply bullet Posted: 16 Jun 2011 at 2:03pm
Anymore than 2 video you really start seeing diminishing returns as far as how well games scale in SLI. What to buy sli 570's vs sli 580's 3gb is a huge price difference. The 570's will def be a bigger bang for the buck. If you want to talk longevity with the option of getting a bigger panel the sli 580 3gb would be nice.
Edited by RiceEatin2000GT - 16 Jun 2011 at 2:04pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Jun 2011 at 1:14am
IF you gonna keep aa settings low go with sli 570, if you want high aa settings go with 6970 cf, its cheaper then sli 580 and has 2GB of ram, which is plenty.
  Quote RadioactiveRabbit Quote  Post ReplyReply bullet Posted: 17 Jun 2011 at 3:36pm
why not go for 580s then arent they the fastest single gpus?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Jun 2011 at 7:04pm
Because at at 1900 x 1200 you won't notice the difference between sli 570 and 580.
between cf 6970 and sli 580 at 2560 x 1600 you won't notice much a difference either.
so to go 580s would be mainly for preference and not performance depending on your res.
Edited by DST4ME - 17 Jun 2011 at 7:04pm
  Quote RadioactiveRabbit Quote  Post ReplyReply bullet Posted: 17 Jun 2011 at 7:33pm
Yeah my res is 2560x 1600 and i plan on going 3 screens in the future after i get this in the fall
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Jun 2011 at 1:46am
You better wait for the highend platform of SB so you can do tri sli/cf, or at least have the option to.
  Quote RadioactiveRabbit Quote  Post ReplyReply bullet Posted: 18 Jun 2011 at 9:03pm
Im ordering this with the highest end stuff i can put in the case alls im trying to figure out now is whether i should go dual 580 3 GB and get the other 2 later or go for some other graphics card
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 19 Jun 2011 at 12:46am
You can't go tri/quad sli on the p67 platform, for that you have to wait for the highend platform (x79) to come put Q4 of this year.
So there is no get one now and add two later, you can only add one more later on this platform.
for that res on 3 monitors, I would either go sli 580 3GB with option to add a third later (which you can't do with the current p67 platform), or go cf 6970 with the option to add a third later (which you can't do with the current p67 platform).
  Quote RiceEatin2000GT Quote  Post ReplyReply bullet Posted: 19 Jun 2011 at 12:00pm
please read thissssssssssssss
  Quote RadioactiveRabbit Quote  Post ReplyReply bullet Posted: 19 Jun 2011 at 1:59pm
Oh ok thank you for the info i didnt now that still pretty knew to building computers.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Jun 2011 at 2:00am
NP that is why we are hear
you have anymore questions feel free to ask
