ATI restore factory default problem
Post Date: 2010-01-01
ntourniquetn View Drop Down
  Quote ntourniquetn Quote  Post ReplyReply bullet Topic: ATI restore factory default problem
    Posted: 01 Jan 2010 at 9:48am
I have a VaporX 5870, which I heard is factory overclocked by 20Mhz. I restored all settings back to standard, and restored factory default. However, since then everytime I restart my computer, my screen looks blurry, out of focus, with very low sharpness and texts look purple. my screen is also shifted.
When I go to CCC under monitor properties / adjustment, all I have to do is to click on any of the four arrows for moving the screen. once I click, instead of moving the screen, the monitor reboot and everything goes back to normal.
I just don't want to do this every time I turn on my computer.
and I feel this isn't a driver issue
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 01 Jan 2010 at 10:25am
make sure you have the resolution set in the CCC to your monitors native resolution first.
  Quote ntourniquetn Quote  Post ReplyReply bullet Posted: 01 Jan 2010 at 11:32pm
=o
Thank you justin
let's see if next restart gives me no trouble
Additionally, I wonder what's the normal temp for 5870 in idle?
mine now is 43 C with 30% fan speed, dual monitor, GPU clock 400 and Memory clock 1200
However, once I check "Enable ATI Overdrive", it drops to 33 C with 30% fan speed, same monitor, GPU 175 and Memory 300.
is there certain benefits of running one mode over the other?
  Quote ntourniquetn Quote  Post ReplyReply bullet Posted: 03 Jan 2010 at 6:07pm
it's strange that everytime I change resolution to anything but 1680x1050, the screen automatically adjust itself for sharpness and size. However once I change it back to 1680x1050, which is the only resolution I am willing to work with, the computer doesn't adjust itself for anything.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 03 Jan 2010 at 6:09pm
you must set it to your monitors native resolution, no if ands or butts.
titusmckieus View Drop Down
  Quote titusmckieus Quote  Post ReplyReply bullet Posted: 03 Jan 2010 at 8:37pm
Originally posted by ntourniquetn
=o
Thank you justin
43 C with 30% fan speed is great. That is what mine run at . and actually I don't even use Overdrive or manual fan control in the catalyst control center. If manual fan control is turned off the fan will increase as the card gets warmer on it's own.
Edited by titusmckieus - 03 Jan 2010 at 8:38pm
