Attaching a Secondary Monitor
Post Date: 2012-07-30
LinkGirl View Drop Down
  Quote LinkGirl Quote  Post ReplyReply bullet Topic: Attaching a Secondary Monitor
    Posted: 30 Jul 2012 at 3:27pm
I found an extra monitor in the house and want to set it up as a secondary monitor, but I'm unsure where to plug it in. I figure I can either plug it into the GTX 670 (using a VGA-DVI adapter, since the monitor only has VGA) or plug it into the ASUS P8Z77-LX mobo. I don't know anything about attaching more than one monitor to a computer, so I was hoping someone could give me some insight on where would be the best place to attach it.
The secondary monitor won't be used for gaming; it'll be used mostly for small tasks (like having Ventrilo or a browser open--for information or watching videos) while gaming or doing other tasks. Also, my current monitor is plugged into the first/top DVI slot.
Thanks in advance. Smile
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 30 Jul 2012 at 3:36pm
Your GTX 670 should have the two DVI ports, the one being used for your current monitor then a second port right next to that one. Just plug the new monitor in (via converter) to that second unused port.
Edited by Tidgxor - 30 Jul 2012 at 3:37pm
This page was generated in 1.953125E-02 seconds.
