audio amps
Post Date: 2008-12-22
Daygn View Drop Down
  Quote Daygn Quote  Post ReplyReply bullet Topic: audio amps
    Posted: 22 Dec 2008 at 1:26am
Anybody know of any good dolby 5.1 amplifiers with s/pdif in and out that I can connect myTritton AX360 to??
BB
widdlecat View Drop Down
  Quote widdlecat Quote  Post ReplyReply bullet Posted: 22 Dec 2008 at 1:30am
What price range are you looking at? If you're looking for under $500 for a surround sound receiver or integrated amp, you're pretty much limited to Japanese brands for your best bang for buck. Korean gear is one other option. If you can afford more, you can get significantly better sound performance for your buck from British manufacturers such as Rotel, etc.
  Quote Daygn Quote  Post ReplyReply bullet Posted: 22 Dec 2008 at 2:19am
under $500 please. I just want it to cleanup and enhance the sound for gaming cause I am stuck using motherboard audio cause my only slot left in my pc is the pcie x1 right above my gpu's and they interfear with my soundcard. I dont need the best sound but also dont want crappy realtech hd audio I have looked but audio equeptment is a mystery to me. On the outher hand if you want ti know about tv's.........
BB
