Audio not working awakening from sleep
Post Date: 2023-05-11
Hort View Drop Down
  Quote Hort Quote  Post ReplyReply bullet Topic: Audio not working awakening from sleep
    Posted: 11 May 2023 at 4:15pm
Frequently, maybe 75% of the time, when waking the machine from sleep, no audio. Not from any port or source.
I've confirmed that the drivers are current etc.
Googling shows a fair number of people with Win 10 and 11 having the issue. New to me with the new Velox - any thoughts where to look?
  Quote Cretae Quote  Post ReplyReply bullet Posted: 11 May 2023 at 6:12pm
Never mind looking. We do not recommend using sleep or hibernate because it does cause issues, sometimes more dire than no sound.
  Quote Snaike Quote  Post ReplyReply bullet Posted: 12 May 2023 at 12:45am
As Cretae mentioned, we do not recommend sleep or hibernate... for any reason for any system. The problems that sleep and hibernate were created to prevent (CRT screen burn-in) are no longer issues and, again as Cretae pointed out, sometimes cause bigger issues than anything they could prevent.
In other words, disable them both: across the entire system. You can either shut your system down when you're finished for the day or just leave it running. I, personally, leave my system on because it is in a non-sleeping room and the lights from the 3 monitors affects no one. That's just me.
Hort View Drop Down
  Quote Hort Quote  Post ReplyReply bullet Posted: 12 May 2023 at 7:56am
Thx guys- first time in 30 years I'd ever had a problem with with sleeping a PC (that I know of) ;)
  Quote hoserator Quote  Post ReplyReply bullet Posted: 13 May 2023 at 9:52am
You have been very lucky. I stopped using "sleep" or hibernate some Window versions ago, Always buggy.  Some leave their systems on all the time and only turns the monitors off (not sleep either) when going to be away. Less trouble with startup.
Smile
This page was generated in 1.757813E-02 seconds.
