Aventum 3 front panel removal.
Post Date: 2022-09-08
RickDanger View Drop Down
  Quote RickDanger Quote  Post ReplyReply bullet Topic: Aventum 3 front panel removal.
    Posted: 08 Sep 2022 at 10:06pm
I need to replace the water pump on my Aventum 3. Radiators are in the way on the sides. So I figure I need to go through the front. How do I remove the front panel? Also what dimension are the fittings and what type of water pump is it?
Edited by RickDanger - 08 Sep 2022 at 10:08pm
  Quote hoserator Quote  Post ReplyReply bullet Posted: 09 Sep 2022 at 2:38am
Welcome and congratulations.
Sorry you are having issues. Those pumps are tough. You sure it failed? If you are running hot, it might be dirty rads and/or fans.
I have an Aventum II and the front panel comes off by pulling on it. Mine has a card reader on it and if yours has one also, be careful with the wires. Mine were glued on.
I got them off by accident when I dropped the panel and the wires came off!
No harm done, fortunately.
On mine the pump is a D5 with a Bitspower Mod Kit. Don't know what was used on yours.
Most fittings are 1/4" but the size of the tubing/hose varies. You will have to call DS. On mine the size is 3/8"ID, 5/8"OD tubing.
Good luck and keep us posted.
Smile
  Quote RickDanger Quote  Post ReplyReply bullet Posted: 09 Sep 2022 at 8:02pm
It might just need to be flushed out really well. I bought my Aventum in 2018, have only flushed it a few times since then. What’s the life on these pumps?
  Quote hoserator Quote  Post ReplyReply bullet Posted: 09 Sep 2022 at 10:42pm
What is it doing that you need to flush the coolant?
Mine was built in 2014 and I have only flushed once because of various leaking fittings that had to be r&r. Still on same pump and hardware. The coolant is still crystal clear.
The D5 pump is rated at 50,000 hours but.....   If it fails, the system has automatic thermal shutdown triggers to avoid damage to the cpu
