Aventum X Cylinder Resovoir Problem
Post Date: 2022-05-15
ChaoticError View Drop Down
  Quote ChaoticError Quote  Post ReplyReply bullet Topic: Aventum X Cylinder Resovoir Problem
    Posted: 15 May 2022 at 11:17pm
I tried opening the cylinder reservoir by removing the lid at the top and in doing so the whole reservoir turned which caused a tiny bit of leakage at the bottom of the cylinder reservoir and hoped some of y’all would know how to fix it
  Quote hoserator Quote  Post ReplyReply bullet Posted: 16 May 2022 at 11:20am
Ouch.
If not leaking now, leave as is. There is a bit of give but not to move back and forth. If still leaking, try to move back to original position. Call DS for an extra bottle of coolant or if not a DS pc, make sure you refill with same coolant as in the system already. You generally cannot mix different coolants. If unknown. use distilled water  to refill.
The reservoir top used to have screw-in caps and needed a 6mm hex wrench to remove. Don't know if still the same. Good luck.
db188 View Drop Down
  Quote db188 Quote  Post ReplyReply bullet Posted: 17 May 2022 at 3:13pm
next time take a hair dryer and heat up the screw top a bit to loosen it up.  heat expansion can get them tight/stuck.
Aventum 3
I7-6700K
Gigabyte G1 Z170X Gaming GT
Corsair Hx1000i 1000W
Gigabyte M28U 4K
This page was generated in 1.953125E-02 seconds.
