Aventum X Drain pipe
Post Date: 2021-07-24
DekloJi View Drop Down
  Quote DekloJi Quote  Post ReplyReply bullet Topic: Aventum X Drain pipe
    Posted: 24 Jul 2021 at 5:16pm
Hi,
First of all thanks for reading my post.
So i have a aventum x for about a 2 years via a giveaway on discord for a Youtuber, so my thing is i was trying to drain this water cooling due to the pc over heating and going to power saving mode. i know that temperature is the issue because when i restart i get MB temp Error.
So now my thing is i cant buy the quick disconnect drain pipe from digital as i don't have the email or order #.
so i am asking someone here for help, i have a few options or you can suggest any.
1) if someone can order a kit for me i can pay you.
2) link me to something similar i can buy for draining.
3) i talked to my local shop he said he would charge $300 to drain it and refill it i mean its quite a lot, he also gave me a another option he said he can rebuild on a different case with the same part he would just change the draining part and charge me 1000 for it.
Please someone guide me what i should do!
Thanks a ton for reading it and i am sorry if this is the wrong place to post.
  Quote Snaike Quote  Post ReplyReply bullet Posted: 24 Jul 2021 at 7:36pm
Have you spoken directly to the head of Customer Service, Alex? ([email protected]) If this was a sponsored contest/giveaway then he should have the information on the machine to get you squared away.
Good luck!!
