aventumx hardline tubing water flow issue
Post Date: 2021-03-04
642500754 View Drop Down
  Quote 642500754 Quote  Post ReplyReply bullet Topic: aventumx hardline tubing water flow issue
    Posted: 04 Mar 2021 at 1:02pm
got my aventumx little over a month, i figured this issue needed some advice so i made a thread here about it.
im little worried that i dont see any water flow in my cpu/gpu block or even the huge block thats located on the other side of my computer, linus acturally mentioned this problem in his youtube video that water flow rate is really low, so i dont know is this normal?
  Quote 642500754 Quote  Post ReplyReply bullet Posted: 04 Mar 2021 at 1:08pm
and here s my build:
Chassis Model: Aventum X
Exterior Finish: Black Metallic Matte Finish
Processor: AMD Ryzen 9 5950X (16-Core) 4.9 GHz Turbo
Motherboard: MSI MEG X570 GODLIKE (Wi-Fi) (AMD X570 Chipset) (Up to 4x PCI-E Devices)
System Memory: 16GB DDR4 3200MHz Digital Storm Performance Series (upgraded to Gskill royal 3600MHZ)
Power Supply: 1600W EVGA Supernova 1600 (80 Plus Gold)
Optical Drive: - No Thanks
Storage Set 1: 1x SSD M.2 (1TB Samsung 980 PRO) (NVM Express)
Storage Set 2: 1x SSD M.2 (1TB Samsung 980 PRO) (NVM Express)
Storage Set 3: 1x SSD M.2 (1TB Samsung 980 PRO) (NVM Express)
Graphics Card(s): 1x GeForce RTX 3090 24GB (Performance Edition) (VR Ready)
Add On Card: - No Thanks
HydroLux Tubing Style: Copper Tubing (Requires HydroLux PRO Custom Liquid Cooling System)
HydroLux Fluid Color: Clear Fluid + Clear Tubing (Requires HydroLux Liquid Cooling System)
Cable Management: Exotic Cable Management - Black - (Cable Combs with Custom Color Sleeved Extension Cables)
Chassis Fans: Corsair LL Series (RGB Fans) (Software Controlled Effects) (14 Fans Total)
Airflow Control: Corsair Commander PRO Management Control Board & Software (3x Boards)
Recovery Tools: - No Thanks
Mouse Pad: - No Thanks
Branded Gear: - No Thanks
Warranty: Life-time Expert Care with 3 Year Limited Warranty (
141816     -- PROMOTIONAL LIMITED TIME BONUS DISCOUNT: $500     1     ($500.00)
MISC     1x Storage (2TB Seagate / Toshiba / Hitachi) By: Andrew.Bain 11/25/2020     1     $84.00
MISC     Corsair AX1600i, 1600 Watt, 80+ Titanium Certified, Fully Modular By: John.Sweger 11/27/2020     1     $879.00
MISC     Special Order Fee By: John.Sweger 11/27/2020     1     $45.00
MISC     Remove 1600W EVGA Supernova 1600 By: John.Sweger 11/27/2020     1     ($560.00)
MISC     GPU Reservation Fee - Asus Brand RTX 3090 By: John.Sweger 11/27/2020     1     $45.00
MISC     rebuild fee By: Hector.Reyes 1/20/2021     1     $65.00
MISC     1 x Bottle Liquid Coolant By: Andrew.Brigance 2/9/2021     1     $0.00
MISC     Rubber Grommet/Washer for Screws that Secure Glass to Case By: Andrew.Brigance 2/9/2021     1     $0.00
  Quote hoserator Quote  Post ReplyReply bullet Posted: 04 Mar 2021 at 1:19pm
Congratulations. That is a very solid system. Strong
Check your temps, which should be fine. I use HWMonitor. I have an old Aventum II with cpu and gpus in the loop and have never seen the coolant (clear) flow.
Enjoy. Smile
We kind, ah, like images you know?
just saying.Chilling
  Quote 642500754 Quote  Post ReplyReply bullet Posted: 04 Mar 2021 at 1:32pm
Enjoy. Smile
cpu avg temps have been 75-85c when playin triple A title (maxed out everthing) is this sound right to u?
GrandesBollas View Drop Down
  Quote GrandesBollas Quote  Post ReplyReply bullet Posted: 04 Mar 2021 at 2:46pm
My mouth drools over systems like yours. Someday as a retirement present to myself!
  Quote hoserator Quote  Post ReplyReply bullet Posted: 05 Mar 2021 at 12:36am
Hmm, that cpu tends to run on the warm side. People are getting your temps and more (90C) at idle. Keep an eye on the temps but game on at your pleasure and keep all clean of dust and with ample space in front of the rads for proper air flow.
You can call DS to let them know and see what they tell you.
adambomb13 View Drop Down
  Quote adambomb13 Quote  Post ReplyReply bullet Posted: 05 Mar 2021 at 7:50am
I have an Aventum X with a hydrolux cooling on 5950X w/ a 3090 and my temps are: using HWINFO64
idle CPU high 40's to low 50's, gaming 56-61, mining 53
CPU has reached 71 (highest) but Im not sure when and how maybe bootup/bios temps
idle GPU low 40's, gaming 50's (max 58 so far), mining 49/
Now so far I have only played Wolcen at 4K ultra/high settings and baldurs gate 3 ultra/high settings, BUT I have tested mining ETH and play Wolcen with plex server streaming movie with a Youtube 8K video playing all at the same time (cpu 60c, 55c) with fans at extreme setting
The way I know my fluid is circulating is looking at the reservoir slight wavy at the top (my fluid level is at 80% of reservoir. but looking at the tubes, reservoir, distro in back or the blocks there are NO bubbles :)
Config ID 3536215- Stg 1 11/13 to 1/4 / Stg 2 as of 1/5 to 1/11 / Stg 3 as of 1/11 / Stg 4 as of 1/11 / Stg 5 as of 1/11 to 1/15 / Stg 6 as of 1/15 / STG 7 shipped 1/18, received 1/26 (5950X,3090)
  Quote hoserator Quote  Post ReplyReply bullet Posted: 05 Mar 2021 at 2:07pm
To the OP: there you go, someone with your hardware.
@adambomb13: With fans at max., are they noisy? There a lot of fans in there. Crazy
  Quote adambomb13 Quote  Post ReplyReply bullet Posted: 05 Mar 2021 at 3:08pm
Not for me, Im coming from an O*****P* eon17-x laptop that had a desktop 7700K and GTX 1080 it sounded like a jet engine. with the digital storm control center you can set it to quiet mode which is extremely quiet for me. I use quiet mode for light tasks and sometimes mining. When I'm gaming Wolcen and mining at the same time I use Extreme Mode which does raise the decibels, My system is in the corner of my living room and my wife has not said it was tooo loud, I personally raise the TV volume a little when in Extreme fan Mod. Now im picky, I do notice a little vibration from one fan on top (exhaust) but I can just tweak the Fine-tune airflow too slow the fans down just a tab and the vibration sound goes away.
Personally I love my Aventum X...its an overpowered beast and Im giddy as a school girl LOL
Update: I put my Apple Watch Series 6 to measure the dB it reached 57dB while the fans were on Extreme Mode. Quite Mode was 40dB thats just insane and again you can tweak the fans/noise with the Fine-Tune Airflow settings
Edited by adambomb13 - 05 Mar 2021 at 3:13pm
This page was generated in 4.785156E-02 seconds.
