Bang for the Buck help
Post Date: 2009-11-30
johnboy View Drop Down
  Quote johnboy Quote  Post ReplyReply bullet Topic: Bang for the Buck help
    Posted: 30 Nov 2009 at 9:49am
Looking for the best bang for the buck.  I am replacing 5 yr old velomicro amd 4000 with 2 ea 7800 gtx in sli.  Want a good computer that is upgradeable to new direct x 11 stat when those cards become plentiful (hello invidia....we're waiting...).  My budget is, as usual, cheap as possible but I can spend around $2000; give or take a hundred if it makes sense.  Need to buy soon (like today), I am using my wife's computer now; and it is SSSSLLLLLLOOOOOOWWWWWW.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 30 Nov 2009 at 11:22am
What resolution will you be gaming at?
  Quote johnboy Quote  Post ReplyReply bullet Posted: 30 Nov 2009 at 8:18pm
I will be getting a new monitor as well, so i would like to use 1920x1080.....but what would be the difference of say between 1920x1080 vs 1680x1050 vs 1360x768 as far as the price of the computer?  Thanks for the help...
satsunada View Drop Down
  Quote satsunada Quote  Post ReplyReply bullet Posted: 30 Nov 2009 at 10:14pm
The higher the resolution, the more powerful the video card/cards required for max settings. 1920x1080 should be ok with a 5870 whereas 1360x768 would be ok with a much less expensive option.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 30 Nov 2009 at 10:26pm
Price: $2073
Chassis Model: Special Deal Hot Seller - HAF 932
Interior Finish: - Not Available
Trim Accents: - Not Available
Card Reader: - Not Available
Liquid Color:- Not Available
Enhancements: - Not Available
Chassis Mods: - Not Available
Boost Memory: - Not Available
Tweak Windows: - Not Available
Office: - Not Available
Benchmarking: - Not Available
LCD Display: - No Thanks
  Quote johnboy Quote  Post ReplyReply bullet Posted: 18 Dec 2009 at 6:40pm
Ouch Thanks for the config dst4me!  Is there any more word on the release date for the new nvidia cards?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Dec 2009 at 6:43pm
no some time within Q1 of 2010. hopping for beginning of it but looks like it might be towards the end of it.
  Quote johnboy Quote  Post ReplyReply bullet Posted: 18 Dec 2009 at 6:49pm
Dst4me, do you think it will be worth the wait; is the performance going to just blow away the ati cards or not really?  I know I am asking you to look at a crystal ball here; but just wondering.....Approve
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Dec 2009 at 6:54pm
the answer to that depends on each person alone, for me and my use yes its worth it, yes they will be more powerful then the ati cards.
if you can wait I would wait, if nothing else at all just to see how they do and the prices, plus when they come out the prices of ati cards should go lower.
  Quote johnboy Quote  Post ReplyReply bullet Posted: 18 Dec 2009 at 7:21pm
ok, some more crystalballing... has ds historically offered better sales nearer christmas / new years than we have right now?  Also, what monitor in the 20"-24" range would you recommend to use at 1920x1080?Cool
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Dec 2009 at 7:35pm
I don't recall to be honest with you.
for 1900 x 1200 a good 24" should be good, the Dell UltraSharp U2410 seems to be a good one, look for a monitor that has the same Viewing Angle, both vertical and horizontal, and is at or above 170°, this is a sign of a quality panel on a monitor, assuring great picture quality.
Edited by DST4ME - 18 Dec 2009 at 7:37pm
