Basic system upkeep
Post Date: 2013-12-29
JelloShot View Drop Down
  Quote JelloShot Quote  Post ReplyReply bullet Topic: Basic system upkeep
    Posted: 29 Dec 2013 at 10:22pm
Are there any Basic maintenance or cleaning tips for my computer(Bolt in stage 3 )? I want to keep it running in mint condition.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 30 Dec 2013 at 3:56am
Hi JelloShot..... Everyone has their own schedule, but I suggest using canned compressed air to blow any dust buildup from the rig.   A couple of times a year, or more often if needed, remove the cover and blow dust away, especially from the inside of the video card and cpu cooler. Dust can build inside the cpu cooler's metal cooling vanes.
Download and run the free CCleaner on a weekly bases to keep junk files from building.   Also, MalWarebytes is good to run weekly to catch any malware, adware, Trojans, etc that your regular virus protection program doesn't catch.
Keep the Bolt off the floor. A couple of feet, or at least several inches, makes a huge difference in dust accumulation inside the rig.
Good luck.
Edited by bprat22 - 30 Dec 2013 at 3:59am
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 30 Dec 2013 at 5:31am
Course if you don't want to use canned air you can use something like this:
http://www.amazon.com/Metro-Vacuum-ED500P-500-Watt-Electric/dp/B001U899HQ/ref=cm_cr_pr_pb_t
Haven't bought it yet but it has good reviews.
Edited by ArkansasWoman777 - 30 Dec 2013 at 5:32am
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 30 Dec 2013 at 6:45am
There is a cheaper version of the Metro Vacuum here:
http://www.amazon.com/Metro-Vacuum-ED500-500-Watt-Electric/dp/B001J4ZOAW
From what I garnered in the reviews, there is no substantive difference between the ED500P (Linked by ArkansasWoman777) and the ED500 (Linked by me). The P modifier on the more expensive one is just referring to a difference in packaging material.
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 30 Dec 2013 at 7:07am
There is a cheaper version of the Metro Vacuum here:http://www.amazon.com/Metro-Vacuum-ED500-500-Watt-Electric/dp/B001J4ZOAWFrom what I garnered in the reviews, there is no substantive difference between the ED500P (Linked by ArkansasWoman777) and the ED500 (Linked by me). The P modifier on the more expensive one is just referring to a difference in packaging material.
Shoot i think thats the same one i was looking at a long time ago but lost the link i had saved. I'll be saving this one to my favorites
  Quote JelloShot Quote  Post ReplyReply bullet Posted: 30 Dec 2013 at 8:46am
Thanks everyone. Very helpful!
ScottishBattleAx View Drop Down
  Quote ScottishBattleAx Quote  Post ReplyReply bullet Posted: 30 Dec 2013 at 12:49pm
I asked a similar question recently.
See here: http://www.digitalstormonline.com/forums/cleaning-your-pc-do-you-do-it-how-tidf21446-kwfcleaning/
There are links in that thread to older threads with more info.
Ignore the advice about using a pressure washer
HAF X // i7-4770K @ 4.2GHZ // Win 8.1 Pro // ASUS Z87-Expert // EVGA GTX 780 Ti Superclocked ACX // 16GB 1866 RAM // 256GB SSD // 2TB + 4TB HDD // Recon3D 5.1 Sound
  Quote JelloShot Quote  Post ReplyReply bullet Posted: 02 Jan 2014 at 3:43pm
I'm going with bprat22. I cleared a spot on my bookshelf that's about 3ft high. And I picked up a few cans of air. I think the bolt might be more at risk of dust buildup because of the tight spacing within the case. Anyone have any experiences with that?
Thanks again everyone for your help
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 02 Jan 2014 at 5:41pm
So we are not, not supposed to not use the pressure washer to not, not clean the system unless you were not referring to not doing the advice above, got it.
Big%20Smile
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 02 Jan 2014 at 7:12pm
So we are not, not supposed to not use the pressure washer to not, not clean the system unless you were not referring to not doing the advice above, got it. Big%20Smile
