Best 24 in Monitor Under 500
Post Date: 2008-08-06
mcs07 View Drop Down
  Quote mcs07 Quote  Post ReplyReply bullet Topic: Best 24 in Monitor Under 500
    Posted: 06 Aug 2008 at 9:26pm
What is the best 24 in monitor for under 500?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Aug 2008 at 9:41pm
you could probably get a Dell Ultrasharp 2408WFP 24" Widescreen LCD for 600 on ebay
  Quote mcs07 Quote  Post ReplyReply bullet Posted: 06 Aug 2008 at 10:33pm
I saw the Gateway FDH2401 in person and it looks great, but I keep reading horrible reviews about it. Maybe its because people don't like the glossy look.
e.fruman View Drop Down
  Quote e.fruman Quote  Post ReplyReply bullet Posted: 06 Aug 2008 at 11:10pm
i have a benq v2400w and its amazing got it for 425$ shipped.
Harry View Drop Down
  Quote Harry Quote  Post ReplyReply bullet Posted: 07 Aug 2008 at 9:08am
I will also be getting a 24" when I order after Nehalem release, I know virtually nothing about them.
I keep reading about poor angle visibility with TN panel.  And since most lower cost panels are apparently TN I am in a bit of a dilemma.
Newegg reviews on TN panels seem kinda brutal.
Are they really that bad?
This will be a major decision for me.  If I am going to spend a ton for a DSO, I want a good display.
Cool Master HAF 932
Core i7 965 DSO OC
Water cooled CPU
ASUS Rampage II Extreme
6 GB DDR3 1600 OCZ
1000 W Corsair HX
GTX 470
300 GB Raptor
tera 7200rpm
Windows 7
nomec View Drop Down
  Quote nomec Quote  Post ReplyReply bullet Posted: 07 Aug 2008 at 9:27am
To be honest, I would suck it up and get a non TN panel.  That is, if you can't handle the viewing angles.  There is a reason they are cheaper priced than non TN panels.  I tried out a Samsung 245BW for a few days and wound up returning it to Best Buy.  Sure, it was a 5ms screen but unless your eyes are lined up with the upper portion of the screen when you're sitting you will see that the screen will look darker towards the top.  I really didn't want to have to think about how I was sitting and adjusting myself the whole time I was using my monitor trying to enjoy a game.  It bothers some people, and to some it doesn't really matter.
I went with an LG L246WP and I couldn't be happier - it's an M-PVA panel.  It's a 8ms screen but that doesn't mean there is ghosting... in fact, there is none at all that I have seen.  Although the price tag was a bit more, I still got it for under $600.
QX6850 @ 3.33ghz
Nvidia 680i A1
4gb pc1066 RAM
2x GTX 275s
Vista Home Premium 64-bit
Gary View Drop Down
  Quote Gary Quote  Post ReplyReply bullet Posted: 07 Aug 2008 at 9:46am
ive got a Samsung 245BW and i love it.It is alittle darker on the edges but when you get use to it you dont even see it.I also sit right straight i front of it.Great monitor for the price.
Edited by Gary - 07 Aug 2008 at 9:47am
Tyler Lowe View Drop Down
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 07 Aug 2008 at 11:22am
My advice is very simple. Do not rely on the advice of others when shopping for either monitors or speakers if you have the capability to get yourself to a Bestbuy or Microcenter or other brick and mortar retail center for computer parts and accessories. Everyone's eyes and ears are different, and the way we percieve the same information will vary greatly from one person to the next. Some people couldn't pinpoint the differences between a $250,000 reference audio setup and a $500 Sony compact stereo, while others could probably tell you if someone switched out the patch cords in that imaginary reference setup. The only real judge of any type of device designed as an interface with one of your senses is you.
MarkNY View Drop Down
  Quote MarkNY Quote  Post ReplyReply bullet Posted: 07 Aug 2008 at 11:31am
I have question. My screen is the apple cinema display 30''.  The response time is 16ms.  Sometimes I notice tearing on certain games (like the intro movie on crysis)- is this due to the game or the screen?
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 07 Aug 2008 at 11:40am
Possibly an SLI issue. Try disabling the SLI and watching the same intro again.
SunfighterLC View Drop Down
  Quote SunfighterLC Quote  Post ReplyReply bullet Posted: 07 Aug 2008 at 11:51am
16ms?!
E8500@ 4.03Ghz
XFX 790i Ultra
1000W Corsair HX
2 280 GTX EVGA FTW
4GB OCZ Reaper 1800Mhz
250-80-300GB VR HD
Logitech Z-2300 2.1 Speakers
Asus Xonar 7.1
  Quote MarkNY Quote  Post ReplyReply bullet Posted: 07 Aug 2008 at 12:04pm
That's what it lists on the apple store site. I was a bit suprised as well...maybe I should look into a more suitable gaming replacement or is that extra 8-11ms really worth it?
Although, I bet I could find a better contrast ratio now too.
probably a waste of money overall... but i like wasting money.
wright View Drop Down
  Quote wright Quote  Post ReplyReply bullet Posted: 07 Aug 2008 at 12:43pm
My second monitor is a 24 "  Samsung..... I think I paid $ 480 for it at Best Buy...It's a great monitor I think for the money....Smile
Hailstorm ll
i7 4770K OC
Z 87 Chip set
16 GB DDR3 1866 MHz
Stage 2 cool 240mm Radiator
GPU 1x GTX 780 3GB
Samsung 256GB SSD
1TB WD Caviar
Corsair 120mm performance fans
widdlecat View Drop Down
  Quote widdlecat Quote  Post ReplyReply bullet Posted: 07 Aug 2008 at 3:12pm
I wholeheartedly agree with Tyler! I've listened to the best audio systems in the world,(well, most expensive system was retail $1.5 million US) and while some people can't tell the differences in systems, others can. Also, I met many people who truly loved the sound of what I can only describe as gawdawful and they didn't like the more musical sound of my system. So, it's all in personal preference. The same is true in how we visually perceive things.
P.S. Tyler, I spent years writing a column on interconnects and cables, changing them in and out of my system quite frequently! Yes, I always heard a difference, but most designed compromised one aspect of sound for another. It did teach me that not all engineers are as good at Physics as others... I can't believe how many engineers try to bend the laws of Physics to make a "new" product.
Seelig View Drop Down
  Quote Seelig Quote  Post ReplyReply bullet Posted: 07 Aug 2008 at 4:05pm
I highly recommend the Sceptre X24WG-1880P.    www.sceptre.com
They are so good, I have two of them.
Can usually find them for under $400 too.
Core 2 Quad QX6850
nForce 780i
4 GB DDR2 Corsair 1066 Dominator
150GB Raptor + 2x WD 750GB
GTX 260
AC3 Cooling
  Quote Seelig Quote  Post ReplyReply bullet Posted: 07 Aug 2008 at 4:08pm
Heh, had a typo and no way to edit.
I highly recommend the Sceptre X24WG-1080P.    www.sceptre.com
Core 2 Quad QX6850
nForce 780i
GTX 260
AC3 Cooling
  Quote Harry Quote  Post ReplyReply bullet Posted: 07 Aug 2008 at 4:57pm
If I lived in a place where I could buy a unit and take it back if I did not like--all would be good.   Problem is I live in the sticks and I will have mail order.
What I am afraid will happen is that a display may seem great for a while then I will notice problems, then I'm stuck.
So I will most likely go with a non TN display just to be on the safe side.
Harry
Cool Master HAF 932
Core i7 965 DSO OC
Water cooled CPU
6 GB DDR3 1600 OCZ
1000 W Corsair HX
GTX 470
300 GB Raptor
tera 7200rpm
Windows 7
jimbos123 View Drop Down
  Quote jimbos123 Quote  Post ReplyReply bullet Posted: 09 Aug 2008 at 3:32am
what do you think of the dell  S2409W  24 inch 1920 by 1200 for only 379?
This page was generated in 0.125 seconds.
