Best 30" LCD monitor?
Post Date: 2008-08-26
Nickdapimp View Drop Down
  Quote Nickdapimp Quote  Post ReplyReply bullet Topic: Best 30" LCD monitor?
    Posted: 26 Aug 2008 at 3:15pm
I want a 30 inch monitor for my new DSO machine since I ran out of monitors(Had 9 monitors, range from 20-30 inch) so any suggestions?
david5182 View Drop Down
  Quote david5182 Quote  Post ReplyReply bullet Posted: 26 Aug 2008 at 7:47pm
Gateway XHD3000 is the best 30" LCD out there.
  Quote Nickdapimp Quote  Post ReplyReply bullet Posted: 26 Aug 2008 at 7:55pm
My friend has that and all I can say is...its amazing! I just wanted to double check and see what else was out there, I'll probably buy 3 of them and make them into a FSX / Racing Sim display...I think my new DSO rig will be my new FX / Racing Sim machine =P
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 Aug 2008 at 4:49am
If that response time is truely from gray to gray, then that is pretty good, but that area has more holes in it then contrast raito
MarkNY View Drop Down
  Quote MarkNY Quote  Post ReplyReply bullet Posted: 28 Aug 2008 at 11:49am
hrm. I am seriously considering upgrading from my 30 Apple Cinema Display to a new monitor.. The Gateway above seems nice and its reasonably priced- it looks kind of ugly (not that that really matters though).. I was also looking into some 24" monitors- think I'll be disapointed going from a 30 to a 24?  I am kind of disapointed that my current monitor has a 16ms response time.
  Quote MarkNY Quote  Post ReplyReply bullet Posted: 28 Aug 2008 at 11:52am
p.s.- what is that horizontal bar in the fron of the gateway? a speaker? is it removable?
  Quote Nickdapimp Quote  Post ReplyReply bullet Posted: 28 Aug 2008 at 12:52pm
MarkNY: You don't like the 30 Apple Cinema Display? I heard it got rated one of the best displays all time!
Yes going from a 30 to 24 will make you a sad panda, I went from a 34 to 26 for a little better resolution and I was still choosing the 34
JC View Drop Down
  Quote JC Quote  Post ReplyReply bullet Posted: 28 Aug 2008 at 8:00pm
Well I will pitch in with a Samsung recommendation. I work with graphics and the Samsung has one of the widest gamuts of the available 30" monitor out there, I think even better then the Apple, quality is astonishing and the device itself is quite stylish.
Follow the octo-core...
