Best 30" Monitor?
Post Date: 2008-01-12
Rumpel View Drop Down
  Quote Rumpel Quote  Post ReplyReply bullet Topic: Best 30" Monitor?
    Posted: 12 Jan 2008 at 1:44pm
I'm looking to get a 30" Monitor...anybody have an opinion about which one is the best?
MarkNY View Drop Down
  Quote MarkNY Quote  Post ReplyReply bullet Posted: 12 Jan 2008 at 5:23pm
I'm not sure which is the best. I've never compared any of the top 30 inch models side by side. I do, however own the apple 30 inch and I love it. I would def recommend going to an apple store and checking it out before buying.
Akkim View Drop Down
  Quote Akkim Quote  Post ReplyReply bullet Posted: 13 Jan 2008 at 3:30am
I have a Dell 30" and I love it. It definitely takes a while to get used to... =)
--Akkim
nomec View Drop Down
  Quote nomec Quote  Post ReplyReply bullet Posted: 13 Jan 2008 at 12:57pm
The Dell 30" is easily one of the best and most people have them.  Actually they also have a newer model it looks like and extremetech gave it really good reviews, but it is a little more expensive: http://www.extremetech.com/article2/0,1697,2244043,00.asp
They also review the Gateway XHD3000 which supposedly was their previous best 30" tested: http://www.extremetech.com/article2/0,1697,2192645,00.asp
I doubt you will go wrong with either of these.
Edited by nomec - 13 Jan 2008 at 12:58pm
QX6850 @ 3.33ghz
Nvidia 680i A1
4gb pc1066 RAM
2x GTX 275s
Vista Home Premium 64-bit
  Quote Rumpel Quote  Post ReplyReply bullet Posted: 14 Jan 2008 at 10:59am
Thanks for the info...somebody told me that Gateway is making a new one that is supposed to be good.
p0ptart View Drop Down
  Quote p0ptart Quote  Post ReplyReply bullet Posted: 14 Jan 2008 at 4:46pm
Got a dell and love it.  no complaints (but then I only use if for my comp, not as a media center).  The new Dells have multiple inputs and is worth the extra bit if you think you might hookup other devices (dvd player, xbox360, ps3) to the monitor.  I hear the Gateway XHD3000 is great for a media center setup but run real hot especially if you're sitting 24 inches away from it.
680i Core 2 Quad A-1 Rev (GO)
Q6600 2.7GHz
Vista Prem. 64bit
8GB DDR2 G.Skill 800MHz
8800GT 512MB
150GB Western Digital Raptor
750W Thermaltake (Pro Case)
30" Dell 3007WFP-HC
