Best build for ~$3k?
Post Date: 2009-02-21
machonmaigle View Drop Down
  Quote machonmaigle Quote  Post ReplyReply bullet Topic: Best build for ~$3k?
    Posted: 21 Feb 2009 at 2:21pm
So I, like many it seems, came across DS through a couple of reviews on some other sites. Overall, seems like everyone here is happy and the machines appear to be very nice.
So, my question is pretty simple (I think at least). What's the best config for ~$3k?
My needs are gaming first (24" 1920x1200), music storage second. I dont need an operating system installed (which I really appreciate DS offering in the first place), I need a fair amount of space for virtualization purposes, and lastly, I'll code on the machine.
I've messed with configs from watercooled 920s to air-cooled 940s, 295s, 285s, blah blah. Wondering what others thoughts are.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Feb 2009 at 4:07pm
here you go Ticket# 250594 --- Price: $3185 (To see this build click here)
System Memory: 6GB DDR3 1333MHz Corsair Dominator DHX (High-Performance)
Power Supply: 1000W Silverstone OP1000-E (Dual/Triple/Quad SLI Compatible) (Silent Edition)
Card Reader: - No Thanks
Hard Drive Set 2: Multimedia\Data: 500GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Video Card: 1x NVIDIA GeForce GTX 295 1.792GB (Includes PhysX Technology)
Liquid Color:UV Green: High Glowing Non-conductive Fluid (Requires H20: Stage 3 & UV Lighting)
LCD Display: - No Thanks
  Quote machonmaigle Quote  Post ReplyReply bullet Posted: 22 Feb 2009 at 10:02pm
Thanks. Any idea what the upkeep is on liquid cooling?
Dsnewb210 View Drop Down
  Quote Dsnewb210 Quote  Post ReplyReply bullet Posted: 22 Feb 2009 at 10:11pm
Change the liquid every 3-5 years and refill as needed... Very simple Ouch
PatrickB View Drop Down
  Quote PatrickB Quote  Post ReplyReply bullet Posted: 22 Feb 2009 at 10:25pm
Don't you need to possibly add a little liquid every 6months or so? Or did i read this wrong somewhere?
Q9550 @ 3.4Ghz for now
Xigmatek Thor's Hammer
MSI P45 Neo2-fr
6gig 1066 Corsair Dominator
XFX Radeon HD 4890
PC Power&Cooling 750W
Seagate Barracuda 500Gb
Antec 900
Vista 64bit
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 22 Feb 2009 at 10:37pm
you check it once a month by simply looking at it inside the case if it needs refill then you just simply add a bit.
lgm25c View Drop Down
  Quote lgm25c Quote  Post ReplyReply bullet Posted: 23 Feb 2009 at 2:52am
Too bad they don't come with a dipstick so you wouldn't have to bother opening the case just to check the level. Smile
Wait...that's not a bad idea! Well, if I've thought of it, surely someone's already implemented it.
  Quote <8) slunK parade Quote  Post ReplyReply bullet Posted: 23 Feb 2009 at 2:58am
the resevoir is clear, completey destroying your dipstick idea ;D
  Quote machonmaigle Quote  Post ReplyReply bullet Posted: 23 Feb 2009 at 6:42am
Cool, thanks.
So the other question I would have it why the 920 water cooled vs the 940 with an air cooled upgrade?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 23 Feb 2009 at 2:56pm
thats upto you, the 920 costs less and we have seen it go as far as 3.8GHz, but we have also seen it do 3.2GHz.
